Introdução
Follow this guide to replace the screen on your Lenovo YOGA 730-15IKB.
Before you jump to replacing the screen, try detaching and reattaching the display connector. This seems to solve many display flickering issues. See the troubleshooting page for more information about this common issue.
If the computer is turning on but the display is black, you might need to replace the screen. You could also replace the screen if it is cracked or if it starts getting dead or stuck pixels (again, see the troubleshooting page for more information).
Ferramentas
Peças
Nenhum componente especificado.
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
Remove the black and white antenna wires from the groove on the right side of the fan.
Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
You can also use the white tabs on the connector to push the cable free.
Remove the fingerprint reader ribbon cable located at the bottom left of the motherboard.
Pull up on the black tab on the connector.
The ribbon cable should easily pull out of the connector.
2 outras pessoas concluíram este guia.
