Introdução
Follow this guide to replace or remove the heat sink in your Lenovo YOGA 730-15IKB. The heat sink transfers heat away from the central processing unit (CPU) and graphics processing unit (GPU). The fans blow cool air over the heat sink to keep it and the other components from overheating.
Sometimes, removing the heat sink and replacing the thermal paste on the CPU with high quality paste can make your computer run faster or cooler. You will also need to remove the heat sink if you are replacing your motherboard.
O que você precisa
Flip the laptop over so you can see the underside.
Remove the ten 7mm T5 Torx screws.
Remove the black and white antenna wires from the groove on the right side of the fan.
Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
You can also use the white tabs on the connector to push the cable free.
Uma outra pessoa concluiu este guia.
