Ir para o conteúdo principal
Lenovo YOGA 730-15IKB Fingerprint Reader Replacement
O que você precisa
  1. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Bottom Cover: passo 1, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Turn off the computer and unplug the charger before going any further.
    • Flip the laptop over so you can see the underside.
    • Remove the ten 7mm T5 Torx screws.
  2. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 2, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 2, imagem 2 %32
    • Pry up the bottom cover with an opening tool.
    • Start at the front edge of the cover and make your way along the sides.
  3. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 3, imagem 1 %32
    • Pull the bottom cover up and away from the back hinges.
  4. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Battery: passo 4, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Battery: passo 4, imagem 2 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Battery: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect the battery from the motherboard by gently pulling the battery cable using your fingers or a pair of tweezers.
    • Pull parallel to the battery, not straight up.
    • Unplug the cable gently as the eight wires on the connector are very small and delicate.
  5. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 5, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 5, imagem 2 %32
    • Remove the four 4mm Phillips #1 screws securing the battery.
  6. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 6, imagem 1 %32
    • Lift the battery up and out of the chassis.
    • Handle the battery carefully. Touching the terminal may cause electric shock. Puncturing the battery may cause it to catch fire.
  7. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Left Fan: passo 7, imagem 1 %32
    • When the laptop is upside down, the left fan is on the right side of the laptop near the wireless card and the SSD.
    • Remove the black and white antenna wires from the groove on the right side of the fan.
  8. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 8, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 8, imagem 2 %32
    • Disconnect the fan cable. Pull the wire toward the right side of the laptop while wiggling to loosen the connection.
    • You can also use the white tabs on the connector to push the cable free.
  9. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 9, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 9, imagem 2 %32
    • Remove two 4mm Phillips #1 screws.
  10. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 10, imagem 1 %32
    • Pull the fan up and towards the front of the laptop.
  11. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Right Fan: passo 11, imagem 1 %32
    • When the laptop is upside down, the right fan is on the left side of the laptop near the large metal RAM cover.
    • Disconnect the fan cable. Pull the wire toward the back of the laptop while wiggling to loosen the connection.
  12. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 12, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 12, imagem 2 %32
  13. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 13, imagem 1 %32
  14. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Motherboard: passo 14, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Motherboard: passo 14, imagem 2 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Motherboard: passo 14, imagem 3 %32
    • Remove the fingerprint reader ribbon cable located at the bottom left of the motherboard.
    • Pull up on the black tab on the connector.
    • The ribbon cable should easily pull out of the connector.
  15. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 15, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 15, imagem 2 %32
    • Remove the three other ribbon cables at the lower edge of the motherboard.
    • For each, lift up the black tab on the connector.
    • The ribbon cables should easily pull out of the connectors.
  16. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 16, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 16, imagem 2 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 16, imagem 3 %32
    • Disconnect the speaker cable by pulling the wire towards the front of the laptop.
  17. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 17, imagem 1 %32
    • Remove the sticky tape from the top of the wireless card.
  18. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 18, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 18, imagem 2 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 18, imagem 3 %32
    • Pull the black and white antenna wires off of the wireless card.
    • For reassembly, the white wire connects to the right terminal marked "1." The black wire connects to the left terminal marked "2."
  19. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 19, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 19, imagem 2 %32
    • Pull up on the thick gray display cable near the back of the laptop to disconnect the display.
  20. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 20, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 20, imagem 2 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 20, imagem 3 %32
    • The charger port is connected to the computer by a cable at the top left of the motherboard.
    • Disconnect the cable by pulling the bundle of wires firmly toward the back of the laptop.
    • The cable requires some force to remove. Make sure you do not damage the connector or cable.
  21. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 21, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 21, imagem 2 %32
    • Remove four 4mm Phillips #1 screws.
  22. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 22, imagem 1 %32
    • Pull the motherboard up out of the laptop chassis.
    • If you are replacing the motherboard, make sure to remove the SSD, wireless card, heat sink, and extra RAM. Transfer these components to the new motherboard.
  23. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Fingerprint Reader: passo 23, imagem 1 %32 Lenovo YOGA 730-15IKB Fingerprint Reader Replacement, Fingerprint Reader: passo 23, imagem 2 %32
    • Remove one 2mm Phillips #1 screw.
  24. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 24, imagem 1 %32
    • Remove the small metal plate from above the reader.
    • The ribbon should be kept in case the new fingerprint reader doesn't come with a new ribbon to connect it to the motherboard.
  25. Lenovo YOGA 730-15IKB Fingerprint Reader Replacement: passo 25, imagem 1 %32
    • Pull the fingerprint reader up out of the chassis.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
Cal Poly, Team S1-G6, White Winter 2020 Membro de Cal Poly, Team S1-G6, White Winter 2020
CPSU-WHITE-W20S1G6
Membros da 3
Autoria de 27 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 722
