Ir para o conteúdo principal
Joy-Con 2 (Right) Battery Replacement
O que você precisa
  1. Joy-Con 2 (Right) Battery Replacement, Remove the left edge screws: passo 1, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Remove the left edge screws: passo 1, imagem 2 %32
    • Use a tri-point Y00 driver to remove the two 3.1 mm‑long black screws on the left edge of the controller.
    Pergunte ao FixBot
    Comentar
  2. Joy-Con 2 (Right) Battery Replacement, Insert an opening pick: passo 2, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Insert an opening pick: passo 2, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Insert an opening pick: passo 2, imagem 3 %32
    • Insert an opening pick into the gap underneath the bumper button on the right side of the controller, with a point of the pick pointing downwards.
    • Pry up to slightly lift the plastic strip running across the right edge of the controller.
    • Slide the opening pick around to the front of the controller.
    Pergunte ao FixBot
    Comentar
  3. Joy-Con 2 (Right) Battery Replacement, Separate the plastic strip: passo 3, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Separate the plastic strip: passo 3, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Separate the plastic strip: passo 3, imagem 3 %32
    • Slide the opening pick down the plastic strip to separate the clips and adhesive securing it to the controller's body.
    Pergunte ao FixBot
    Comentar
  4. Joy-Con 2 (Right) Battery Replacement, Remove the plastic strip: passo 4, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Remove the plastic strip: passo 4, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Remove the plastic strip: passo 4, imagem 3 %32
    • Pry up on the bottom edge of the plastic strip with slow, steady force.
    • Repeat this prying action along the length of the strip until it's fully detached.
    Pergunte ao FixBot
    Comentar
  5. Joy-Con 2 (Right) Battery Replacement: passo 5, imagem 1 %32
    • Remove the plastic strip.
    Pergunte ao FixBot
    Comentar
  6. Joy-Con 2 (Right) Battery Replacement, Remove the right edge screws: passo 6, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Remove the right edge screws: passo 6, imagem 2 %32
    • Remove the two screws on the right edge of the controller:
    • One 3.1 mm‑long tri-point Y00 black screw
    • One 3.0 mm‑long JIS 00 silver screw
    • You can use a Phillips screwdriver in a pinch, but you risk damaging or stripping the screw. Push down firmly on the screwdriver and twist slowly. Often, switching drivers may help, even if they're the same size.
    Pergunte ao FixBot
    Comentar
  7. Joy-Con 2 (Right) Battery Replacement, Insert an opening pick: passo 7, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Insert an opening pick: passo 7, imagem 2 %32
    • Don't try to remove the back cover yet.
    • Insert an opening pick into the gap between the front and back halves of the controller on its right side.
    • Slide the pick down the controller to disengage the clips.
    • Leave the opening pick at the bottom of the controller's right edge, just before its curve.
    • The opening pick will fall out once the back cover is removed. If it falls out before then, put it back to keep the two halves separated.
    Pergunte ao FixBot
    Comentar
  8. Joy-Con 2 (Right) Battery Replacement, Insert a second opening pick: passo 8, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Insert a second opening pick: passo 8, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Insert a second opening pick: passo 8, imagem 3 %32
    • Hold the controller upside-down.
    • Insert a point of another opening pick next to the release button towards the top of the controller.
    • Use the opening pick to press the release button through the gap.
    Pergunte ao FixBot
    Comentar
  9. Joy-Con 2 (Right) Battery Replacement, Release the back cover: passo 9, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Release the back cover: passo 9, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Release the back cover: passo 9, imagem 3 %32
    • The back cover is connected to the controller by a cable at the bottom. Don't try to remove it completely yet.
    • While holding the release button with the opening pick, use your other hand to slide the back cover down to release the clips securing it to the controller's body.
    • Open the back cover.
    Pergunte ao FixBot
    Comentar
  10. Joy-Con 2 (Right) Battery Replacement, Remove the back cover: passo 10, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Remove the back cover: passo 10, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Remove the back cover: passo 10, imagem 3 %32
    • Firmly grasp the two wires (yellow and white) above the rumble motor connector, located at the bottom of the controller's board, and pull the beige connector out of its socket.
    • Pulling the cable won't damage it, but don't dig your nails into the plastic sheathing.
    • Remove the back cover.
    Pergunte ao FixBot
    Comentar
  11. Joy-Con 2 (Right) Battery Replacement, Disconnect the battery: passo 11, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Disconnect the battery: passo 11, imagem 2 %32
    • Use tweezers or your fingers to firmly grip the battery cable's white JST connector and pull straight away from its socket to disconnect it.
    • Once partially lifted, reposition your fingers/tweezers to beneath the connector's upper lip to increase your grip.
    Pergunte ao FixBot
    Comentar
  12. Joy-Con 2 (Right) Battery Replacement, Remove the battery: passo 12, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Remove the battery: passo 12, imagem 2 %32
    • Insert a flat edge of an opening pick into the gap between the battery and the battery well.
    Pergunte ao FixBot
    Comentar
  13. Joy-Con 2 (Right) Battery Replacement: passo 13, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement: passo 13, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement: passo 13, imagem 3 %32
    Ferramenta utilizada neste passo:
    iFixit Adhesive Remover
    $19.99
    • Pry the battery up slowly with steady force to release the adhesive.
    • Don't bend or crease the battery—apply steady force and give the adhesive time to release.
    • If it feels stubborn, apply a few drops of adhesive remover or high-concentration (90% or higher) isopropyl alcohol to the battery side of the pick while it's inserted and allow it to run under the battery. Be careful not to spill it elsewhere in the controller.
    • If you're using adhesive remover, follow these preparation steps first.
    • Remove the battery.
    Pergunte ao FixBot
    Comentar
  14. Joy-Con 2 (Right) Battery Replacement, Disassembly complete: passo 14, imagem 1 %32
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your console.
    Pergunte ao FixBot
    Comentar
  15. Joy-Con 2 (Right) Battery Replacement, Clean the frame: passo 15, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Clean the frame: passo 15, imagem 2 %32
    Cotton Swabs
    • Apply isopropyl alcohol to a cotton swab and wipe any adhesive residue from the frame.
    • The foam on the inside walls of the frame dissolves in isopropyl alcohol. Avoid damaging the foam.
    Pergunte ao FixBot
    Comentar
  16. Joy-Con 2 (Right) Battery Replacement, Transfer the foam: passo 16, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Transfer the foam: passo 16, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Transfer the foam: passo 16, imagem 3 %32
    • If your replacement battery includes new foam, skip this step.
    • Use an opening pick or your fingernail to lift the foam off the battery by its adhesive, not the foam itself.
    • Carefully peel the foam sticker off the old battery. Avoid stretching or tearing the foam.
    • If the foam does tear, apply the pieces to the replacement battery in their original shape.
    • Apply the foam sticker to the new battery so the edges of the foam are aligned with the edges of the battery.
    Pergunte ao FixBot
    Comentar
  17. Joy-Con 2 (Right) Battery Replacement, Install the battery: passo 17, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Install the battery: passo 17, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Install the battery: passo 17, imagem 3 %32
    Tesa 61395 Tape
    $2.95
    • If your replacement battery came with adhesive pre-installed, peel off any adhesive liners.
    • If your replacement battery doesn't include new adhesive, use thin, double-sided tape instead. If you're using our pre-cut card, cut one of the 5 mm strips so it's half as long, and apply the strips to the back of the battery.
    • Align the battery with its housing. Ensure the battery cable lines up with its channel.
    • Lower one side of the battery, then the other, into its housing.
    • Press and hold on the battery for 10 seconds to bond the adhesive.
    Pergunte ao FixBot
    Comentar
  18. Joy-Con 2 (Right) Battery Replacement, Check the release button: passo 18, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Check the release button: passo 18, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Check the release button: passo 18, imagem 3 %32
    • The release button isn't secured, and falls out easily.
    • Check that the release pin sticks out of the controller when the release button is pressed. If it doesn't, or if the button fell out entirely, re-insert the button and try again.
    Pergunte ao FixBot
    Comentar
  19. Joy-Con 2 (Right) Battery Replacement, Connect the battery: passo 19, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Connect the battery: passo 19, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Connect the battery: passo 19, imagem 3 %32
    • Align the battery connector over its socket on the board.
    • Press down on the connector until it's fully seated.
    Pergunte ao FixBot
    Comentar
  20. Joy-Con 2 (Right) Battery Replacement, Connect the rumble motor: passo 20, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Connect the rumble motor: passo 20, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Connect the rumble motor: passo 20, imagem 3 %32
    • Align the rumble motor connector to its socket on the bottom edge of the board, and push down until it's fully seated to connect it.
    Pergunte ao FixBot
    Comentar
  21. Joy-Con 2 (Right) Battery Replacement, Install the back cover: passo 21, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Install the back cover: passo 21, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Install the back cover: passo 21, imagem 3 %32
    • Use an opening pick to press and hold the release button.
    • Place the back cover over the controller body so the release button cutout is slightly below the release button.
    • The release button is held down when the release pin is protruding from the frame. If the release button falls out of position, put it back and try again.
    • Press and slide the back cover up until the cut-out for the release button is aligned with the button itself.
    • Ensure the rumble motor wires (yellow & white) are fully within the frame.
    Pergunte ao FixBot
    Comentar
  22. Joy-Con 2 (Right) Battery Replacement: passo 22, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement: passo 22, imagem 2 %32
    • Remove the opening pick.
    Pergunte ao FixBot
    Comentar
  23. Joy-Con 2 (Right) Battery Replacement, Install the right edge screws: passo 23, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Install the right edge screws: passo 23, imagem 2 %32
    • Install the two screws on the right edge of the controller:
    Pergunte ao FixBot
    Comentar
  24. Joy-Con 2 (Right) Battery Replacement, Install the plastic strip: passo 24, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Install the plastic strip: passo 24, imagem 2 %32 Joy-Con 2 (Right) Battery Replacement, Install the plastic strip: passo 24, imagem 3 %32
    • Align the clips on the plastic strip with their cut-outs on the right edge of the controller body.
    • Insert the clips on the bottom edge first, then insert the rest so the plastic strip sits flush.
    Pergunte ao FixBot
    Comentar
  25. Joy-Con 2 (Right) Battery Replacement, Install the left edge screws: passo 25, imagem 1 %32 Joy-Con 2 (Right) Battery Replacement, Install the left edge screws: passo 25, imagem 2 %32
    • Use a tri-point Y00 driver to install the two 3.1 mm‑long black screws on the left edge of the controller.
    Pergunte ao FixBot
    Comentar
Conclusão
You finished fixing your Joy-Con 2!
Don't throw your battery in the trash. Click here to learn how to dispose of it properly.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Joy-Con 2 Answers Community for help.
Nick Schultz
Membro desde: 03/24/24
58.666 Reputação
Autoria de 318 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 34
Últimos 30 dias: 168
Ao todo: 1,588
