Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
In this guide we show you, how to remove and replace the display assembly with frame in your Huawei P10 smartphone.
To protect your eyes from glass shreds and get a better grip to open the phone you might want to apply some tape onto the screen.
When reassembling apply new adhesive where it is necessary. Before reassembly check your new part for any components that might need to be transferred from the old one.
  1. Switch off your phone. Remove the two Pentalobe P2 screws at the bottom. Remove the SIM card tray.
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Insert a plastic opening tool between the display and the case starting at the bottom area of your phone. Carefully pry the display with its parts out of the case. Getting the prying tool in  will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover. Swing open the phone backwards.
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Remove the two Phillips #00 screws.
    • Remove the two Phillips #00 screws.
  5. Use tweezers to remove the two cable brackets. Use tweezers to remove the two cable brackets.
    • Use tweezers to remove the two cable brackets.
  6. Use a spudger to disconnect the battery, the interconnect and the display flex cable. Use a spudger to disconnect the battery, the interconnect and the display flex cable. Use a spudger to disconnect the battery, the interconnect and the display flex cable.
    • Use a spudger to disconnect the battery, the interconnect and the display flex cable.
  7. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  8. The battery is glued in place with two adhesive strips. One with a pull tab and one without. Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • The battery is glued in place with two adhesive strips. One with a pull tab and one without.
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • It is likely that the adhesive strip rips. In this case you can grab and twist it around a tweezers tip a couple of times and then continue.
    • Use an iOpener to loosen the remaining adhesive.
    • Take care to not bend or puncture the battery.
    • Insert an opening pick or spudger beneath the battery and carefully pry it out.
    • Remove the battery.
    • When reassembling your phone replace old adhesive with double-sided tape or pre-cut adhesive strips.
    • Never reinstall a battery that has been bent or damaged during removal.
  9. Remove the four Phillips #00 screws. Use tweezers to remove the metal plate that covers the charging board and the main flex cable.
    • Remove the four Phillips #00 screws.
    • Use tweezers to remove the metal plate that covers the charging board and the main flex cable.
  10. Use the flat end of a spudger to disconnect the flex cable of the headphone jack. Remove the headphone jack with tweezers. There's a little adhesive underneath so it can be a bit sticky. Unplug the antenna cable with tweezers.
    • Use the flat end of a spudger to disconnect the flex cable of the headphone jack.
    • Remove the headphone jack with tweezers. There's a little adhesive underneath so it can be a bit sticky.
    • Unplug the antenna cable with tweezers.
  11. Disconnect the main flex cable with a spudger and remove it. Disconnect the loudspeaker flex cable. Carefully remove the charging board.
    • Disconnect the main flex cable with a spudger and remove it.
    • Disconnect the loudspeaker flex cable.
    • Carefully remove the charging board.
  12. Remove the vibration motor. If the adhesive is too strong, heat an iOpener to soften it and ease removal. Use the flat end of a spudger to pry up under the speaker. Remove the loudspeaker.
    • Remove the vibration motor. If the adhesive is too strong, heat an iOpener to soften it and ease removal.
    • Use the flat end of a spudger to pry up under the speaker.
    • Remove the loudspeaker.
  13. Remove the rubber gasket with tweezers.
    • Remove the rubber gasket with tweezers.
    • If the gasket is included in your new part, there is no need to remove it from the old one.
  14. Remove the four Phillips #00 screws from the motherboard.
    • Remove the four Phillips #00 screws from the motherboard.
  15. Disconnect the antenna cable and remove it.
    • Disconnect the antenna cable and remove it.
  16. Use the pointed end of a spudger in the top right corner of the motherboard and pry it out until you can get a good grip. The front and the rear cameras are still connected to the motherboard. Don't damage them while you remove the motherboard. Remove the motherboard.
    • Use the pointed end of a spudger in the top right corner of the motherboard and pry it out until you can get a good grip.
    • The front and the rear cameras are still connected to the motherboard. Don't damage them while you remove the motherboard.
    • Remove the motherboard.
    • On the back of the motherboard there are thermal pads (pink rubber-like gobs) for heat dissipation. If these thermal pads broke or are too dried out you might need to apply new thermal pads on the new display assembly or the motherboard.
    • Remove the earpiece speaker with a tweezer.
    • Take care of the metal connectors to not bend them.
    • Carefully remove the proximity sensor from its recess.
    • Before reassembly check your new part for any components that might need to be transferred from the old one.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling apply new adhesive where it's necessary.
14 outras pessoas concluíram este guia.
Dominik Schnabelrauch
Membro desde: 23/11/2016
62.632 Reputação
288 Guias de autoria
Equipe
iFixit Membro de iFixit
Community
124 Membros
11.565 Guias de autoria
Are the pink/purple blobs unter the motherboard thermal paste? If so, should I re-apply any when reassembling?
Martin Düren - Responder
Gonna upload an easy and faster way to do it whitout removibg the battery or upper boards and cameras, wait for it, my 1st guide.
mauro-diaz1 - Responder
I Need screen for p smart huawei2018
mbc judo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 14
Últimos 7 dias: 76
Últimos 30 dias: 282
Duração total: 10,429
