Ir para o conteúdo principal
How to Use the Anti-Clamp
O que você precisa
  1. How to Use the Anti-Clamp, Prepare your device: passo 1, imagem 1 %32 How to Use the Anti-Clamp, Prepare your device: passo 1, imagem 2 %32 How to Use the Anti-Clamp, Prepare your device: passo 1, imagem 3 %32
    • The Anti-Clamp needs smooth, even surfaces for its suction cups to adhere to.
    • If your device has cracked glass or a slippery surface, follow this guide to apply the included tape pad.
    • Packing tape also works to cover a cracked display.
    • If your back glass is badly shattered, the tape might damage it further. Refer to your specific guide to use a suction handle instead.
    • If your device can be opened from both its screen and back cover, follow this guide to apply the included tape strips.
  2. How to Use the Anti-Clamp, Unlock the arms: passo 2, imagem 1 %32 How to Use the Anti-Clamp, Unlock the arms: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • Pull the blue handle backward to disengage the arms of the Anti-Clamp.
    • The handle may be stiff the first time you unlock the arms.
  3. How to Use the Anti-Clamp, Center the suction cups: passo 3, imagem 1 %32 How to Use the Anti-Clamp, Center the suction cups: passo 3, imagem 2 %32 How to Use the Anti-Clamp, Center the suction cups: passo 3, imagem 3 %32
    • Rotate the Anti-Clamp to the side so it doesn't obscure your starting edge. Refer to your original guide for which edge to start with.
    • Center the suction cups over a smooth area of the device near the starting edge.
    • Avoid buttons, gaps, seams, and speakers, as they will prevent a good hold.
  4. How to Use the Anti-Clamp, Secure the suction cups: passo 4, imagem 1 %32 How to Use the Anti-Clamp, Secure the suction cups: passo 4, imagem 2 %32
    • Squeeze the suction cups together to secure them to the device.
    • If the cups are stiff and hard to secure, use your hands to warm them up.
  5. How to Use the Anti-Clamp, Alignment information: passo 5, imagem 1 %32 How to Use the Anti-Clamp, Alignment information: passo 5, imagem 2 %32
    • The suction cups need to be aligned with each other for the Anti-Clamp to work properly.
    • Improper alignment may cause the cups to separate prematurely. Pull the cups off the device using their pull tabs and re-center them.
  6. How to Use the Anti-Clamp, Lock the arms: passo 6, imagem 1 %32 How to Use the Anti-Clamp, Lock the arms: passo 6, imagem 2 %32
    • Push the blue handle forward to lock the arms.
  7. How to Use the Anti-Clamp, Support your device: passo 7, imagem 1 %32
    • Place a support under your device so the Anti-Clamp stands upright without being held in place.
  8. How to Use the Anti-Clamp, Apply tension: passo 8, imagem 1 %32 How to Use the Anti-Clamp, Apply tension: passo 8, imagem 2 %32
    • Most adhesives separate under constant tension rather than more force. Take your time during this process to avoid breaking the suction cups free or violently opening your device.
    • Twist the handle clockwise one full rotation (360 degrees) or until the cups begin to stretch.
  9. How to Use the Anti-Clamp, Heat your device: passo 9, imagem 1 %32 How to Use the Anti-Clamp, Heat your device: passo 9, imagem 2 %32
    • For smaller devices, thread a heated iOpener through the arms of the Anti-Clamp to heat your device.
    • For larger devices, or iPhone models 12 and newer, use a hair dryer or a heat gun to soften the adhesive along your starting edge.
    • iPhone models 12 and newer have a tougher adhesive that the iOpener is less effective at opening than a hair dryer or heat gun.
    • Be careful not to overheat your device. The edge should feel slightly too hot to touch.
  10. How to Use the Anti-Clamp, Open your device: passo 10, imagem 1 %32 How to Use the Anti-Clamp, Open your device: passo 10, imagem 2 %32 How to Use the Anti-Clamp, Open your device: passo 10, imagem 3 %32
    • Wait one minute to give the adhesive a chance to release and present a gap.
    • If the Anti-Clamp doesn't separate the adhesive after one minute, apply more heat and wait another minute. Be patient and let the Anti-Clamp do the work for you.
    • If, after several rounds of heating, the device doesn't show any signs of opening, twist the knob one quarter-turn.
    • Don't twist the knob more than three additional quarter-turns. Only use additional heat at this point. The more you twist the knob, the more likely the device is to suddenly pop open.
  11. How to Use the Anti-Clamp, Insert an opening pick: passo 11, imagem 1 %32
    • Insert an opening pick into the gap created by the Anti-Clamp.
  12. How to Use the Anti-Clamp, Remove the Anti-Clamp: passo 12, imagem 1 %32 How to Use the Anti-Clamp, Remove the Anti-Clamp: passo 12, imagem 2 %32 How to Use the Anti-Clamp, Remove the Anti-Clamp: passo 12, imagem 3 %32
    • Pull the blue handle backward to the unlock icon to disengage the arms.
    • Pull the suction cups off of the device using their pull-tabs.
    • Remove the Anti-Clamp and set your device on a flat surface.
  13. How to Use the Anti-Clamp, Finish opening your device: passo 13, imagem 1 %32
    • Return to your original guide and continue disassembly, skipping any steps that open the device with a suction handle.
Conclusão
For other general electronics skills guides, click here.
For a fun way to decorate your Anti-Clamp, click here.
111 outras pessoas executaram este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
212.515 Reputação
Autoria de 1.037 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.580 guias
10Comentários do guia
Very clear step-by-step guide. The next time I do a battery replacement I intend to use one of these.
4surferboy - Responder
Engaging the Opening Mode the first time takes a bit of a push, don't be afraid, keep pushing until you hear a click. Seems to be easier to engage after the first time.
Ed Reeder - Responder
Hi Ed,
Thanks for the helpful feedback! I've implemented your note into the guide step.
Arthur Shi -
Looks like an answer to a problem that I don't have right now but I plan to purchase one of these before I do any more battery replacements.
glynn - Responder
I used mine to open a Samsung Galaxy Tab A7 tablet. Very frustrating, seemed like you needed three hands to put it in place (though later I found a better procedure). The OEM case glue was quite powerful (used a heating pad to get the tablet Very hot). The Anti-Clamp had difficulty holding to the back of the case and kept losing its grip. I didn't try the packing tape trick, just now noticed it. I mainly used the top suction cup just by itself.
The replacement battery had a very long battery cable and didn't lay flat, which caused a bright spot on the display where the cable "kink" was. So time to remove the case again. This time I stuck each suction cup individually, screen side first, the case - firmly pressing each cup flat after placement. No need to "fight" the Anti-Clamp to get it in place, plus I think I got a better hold with the cups. The B-7000 glue I used was much easier to break loose than the OEM case glue.
To loosen the suction cups I slid an opening pick under the edge of the cup.
Comentar
Visualizações:
Últimas 24 horas: 30
Últimos 7 dias: 216
Últimos 30 dias: 1,071
Ao todo: 56,117
