Ir para o conteúdo principal
How to Use a Desoldering Pump
O que você precisa
  1. How to Use a Desoldering Pump, Prime the pump: passo 1, imagem 1 %32 How to Use a Desoldering Pump, Prime the pump: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • If this is your first time using a desoldering pump, try priming and activating the pump a few times before you use it for desoldering purposes.
    • Firmly grasp the desoldering pump with your hand.
    • Depress the plunger until it locks in place.
    • This primes the spring-loaded piston for suction.
    Pergunte ao FixBot
    Comentar
  2. How to Use a Desoldering Pump, Activate the pump: passo 2, imagem 1 %32 How to Use a Desoldering Pump, Activate the pump: passo 2, imagem 2 %32
    • To activate the pump, press the black side button.
    • This releases the spring-loaded piston, which creates a burst of suction at the nozzle.
    • The piston release creates a substantial kickback. Brace your hand when you use the pump to keep the nozzle steady.
    Pergunte ao FixBot
    Comentar
  3. How to Use a Desoldering Pump, Desolder a joint: passo 3, imagem 1 %32 How to Use a Desoldering Pump, Desolder a joint: passo 3, imagem 2 %32 How to Use a Desoldering Pump, Desolder a joint: passo 3, imagem 3 %32
    FixHub Smart Soldering Iron
    $79.95
    • Do not use the desoldering pump to desolder joints near small surface-mounted (SMT) components. The heat spillover and suction may dislodge the SMT components.
    • Prime the desoldering pump by depressing the plunger.
    • Heat the solder joint until the solder is liquified. To help with heat transfer, add some solder onto the soldering iron's tip.
    • Position the pump's nozzle as close to the molten solder as possible.
    • The nozzle is made of heat-resistant plastic, so don't worry if you occasionally brush the tip with it.
    • Press the side button to activate the pump.
    • Repeat the process until the joint is clean. You can also use solder wick to help soak up any remnant solder.
    Pergunte ao FixBot
    Comentar
  4. How to Use a Desoldering Pump, Clean the desoldering pump: passo 4, imagem 1 %32 How to Use a Desoldering Pump, Clean the desoldering pump: passo 4, imagem 2 %32 How to Use a Desoldering Pump, Clean the desoldering pump: passo 4, imagem 3 %32
    • To clean the pump, prime and activate the pump a few times. This pushes a rod through the nozzle and ensures that solder doesn't block it.
    • On the rare occasion when the pump needs a more thorough cleaning, you can disassemble the pump to clean it out:
    • Grasp the nozzle by its knurled edge.
    • Twist the nozzle counter-clockwise to unscrew it. This may be difficult due to a tight-fitting O-ring.
    • Remove the nozzle and clean out the pump interior.
    Pergunte ao FixBot
    Comentar
Conclusão
For soldering instructions and tips, follow this guide.
93 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
343.666 Reputação
Autoria de 915 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.230 guias
5Comentários do guia
Good review, but I’ve found that these small solder suckers don’t do a very good job. The much larger “Soldapult” (https://www.edsyn.com/product/DS017.html) provides much more suction and can often completely clear a joint in one use.
shamino - Responder Compartilhar
How does the tip not melt.
Mia Cipollone - Responder Compartilhar
Apply higher temperature on your soldering iron, above 380°C.
Use bigger tip, bigger heating surface provides more effecitive heat transfer.
SchwarzeKatz - Responder Compartilhar
If you are asking about why the tip of the solder sucker doesn't melt, it is made of a heat resitant material. Notice the word resistant.
Budda Belly - Responder Compartilhar
Realmente me estoy interesando en este rubro y espero çontinuar aprendiendo para que me sirva como terapia
Jaime Rivera - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 34
Últimos 7 dias: 313
Últimos 30 dias: 1,597
Ao todo: 118,978
