Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Capacitors are electronic components found in almost every device containing a circuit board. Large capacitors can store enough charge to cause injuries, so they must be discharged properly.
While iFixit currently doesn't sell a capacitor discharge tool, you can easily create your own.
O que você precisa
Capacitors come in various shapes and sizes, but the large cylindrical capacitors typically are the ones that store enough energy to be potentially dangerous.
Aluminum electrolytic capacitors, the most commonly used for high voltage, usually look like little tin cans, with both leads extending from the bottom.
Your capacitor is now safe to be handled, shock free!
44 outras pessoas executaram este guia.
