Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Capacitors come in various shapes and sizes, but the large cylindrical capacitors typically are the ones that store enough energy to be potentially dangerous.
Aluminum electrolytic capacitors, the most commonly used for high voltage, usually look like little tin cans, with both leads extending from the bottom.
Identify all the capacitors in your device.
Locate where the capacitor's cathode will be by finding the side of the capacitor marked with a "-" (minus) symbol. This side will correspond to the negative lead, or cathode.
Flip the circuit board over to access the capacitor's leads.
Touch the black, or negative, tip of the discharge pen to the capacitor's cathode.
Touch the red, or positive, tip of the discharge pen to the other lead, the capacitor's anode.
Watch the LED indicator on your discharge tool. If there is still a charge in the capacitor, the LED should glow red until the capacitor is fully discharged.
Once the light is no longer on, your capacitor is fully discharged and safe to handle.
44 outras pessoas executaram este guia.
