Ir para o conteúdo principal
HP ProBook 455 G7 Battery Replacement
O que você precisa
    1. HP ProBook 455 G7 Battery Replacement, Lower Case: passo 1, imagem 1 %32
      • Before beginning, completely power off the laptop and unplug the charger and any peripheries.
      • Flip the laptop over so the lower case is facing up.
      • Use a Phillips #1 screwdriver to remove the seven 8 mm-long screws securing the lower case.
      Pergunte ao FixBot
      Comentar
    2. HP ProBook 455 G7 Battery Replacement: passo 2, imagem 1 %32 HP ProBook 455 G7 Battery Replacement: passo 2, imagem 2 %32 HP ProBook 455 G7 Battery Replacement: passo 2, imagem 3 %32
      • Insert an opening tool into the seam between the lower case and chassis.
      • Pry around the entire perimeter until the lower case fully releases.
      • Lift and remove the lower case.
      Pergunte ao FixBot
      Comentar
    1. HP ProBook 455 G7 Battery Replacement, Battery: passo 3, imagem 1 %32 HP ProBook 455 G7 Battery Replacement, Battery: passo 3, imagem 2 %32 HP ProBook 455 G7 Battery Replacement, Battery: passo 3, imagem 3 %32
      • Use a Phillips #1 screwdriver to remove the three 4 mm-long screws securing the battery.
      • Carefully lift the battery and remove it from the laptop.
      Pergunte ao FixBot
      Comentar
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Equipe
UMass Dartmouth, Team 1-6, Botvin Fall 2025 Membro de UMass Dartmouth, Team 1-6, Botvin Fall 2025
UMASSD-BOTVIN-F25S1G6
3 Membros
Autoria de 24 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 200
