Introdução
Does the battery of your HP ProBook 440 G6 need inspection or replacing? This guide is here to help you safely replace your laptop's battery step-by-step. The battery is an essential part of your device as it supplies portable, untethered power that allows the device to operate without needing to be plugged in to an outlet. Restoring the faulty battery can restore safe and smooth power into your device, but how can you know if the battery is the issue?
Common Symptoms that may arise due to a faulty battery may include:
- Rapid battery drain
- Device shuts down unexpectedly even though the battery isn't fully depleted
- Device overheating
- Device only turns on when plugged in
- slow or no charging at all
This guide will walk you through each step to ensure a safe and smooth replacement. But before beginning this replacement, make sure to power off your device, unplug it from the charger and put it in Battery Safe mode.
O que você precisa
Using a Phillips #0 Screwdriver, remove the two 5 mm screws on the front-facing side of the lower case.
Using a Phillips #0 Screwdriver, remove the remaining five 5 mm Phillips screws securing the lower case.
Starting under the display, carefully use a plastic prying tool (iFixit opening tool) to disengage the retaining clips.
Once a corner or edge starts to lift, slowly slide the tool along the edge to loosen more of the bottom panel.
Keep working around the edges until all the clips are loose.
Using a Phillips #0 Screwdriver, remove the two 4mm Phillips screws that secure the battery to the computer.
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
