Introdução
If the hard drive in your system failed or you just want to replace the drive with a larger drive or an SSD, this guide will show you how to access the hard drive for replacement.
Guide notes
- Sort your screws. Multiple lengths are used and there are lot to sort.
- Hard drive replacement is unnecessarily complicated on this laptop and requires partial disassembly.
- If you are unsure you can do this repair, have it done by a professional.
- If you are unsure if you can do this repair, read the entire guide before opening the laptop.
- This laptop accepts 7mm and 9.5mm drives. Use the 9.5mm bumpers on both drive thicknesses if this is what your system shipped with.
- If your system shipped with a 7mm drive and you are installing a 9.5mm drive, you may need to purchase replacement drive bumpers.
- Test the computer partially disassembled BEFORE reassembly. Complete disassembly is required to correct any issues.
Shut the laptop down until it is hibernated or shut off. Do not remove power until both lights turn off.
Once the computer is off, remove the battery. Switch the locking tab to the unlocked position.
Remove the battery. Pull the battery forward and remove it from the laptop.
Remove the screw that holds the optical drive in. To do this, use a Phillips #0 screwdriver. Slide the optical drive out once the screw is removed.
Once the battery and optical drive are removed, remove the 11 screws that secure the palmrest.
This screw is hidden by a stick on cover. If lost, this is only cosmetic.
Not found on all models. On some models, there are screws in this area. If you see screws here, they must be removed.
Remove the hinge caps. To do this, remove the rubber pads. Use a Phillps #0 screwdriver.
Remove the screws under the hinge caps. To do this, use a Phillps #0 screwdriver.
With the palmrest screws removed, remove the screws under the optical drive. Use a Phillips #000 screwdriver.
Use a plastic tool to remove the palmrest. Once all 3 sides are loose, disconnect the keyboard and trackpad. Flip the black plastic tabs on the connectors up to remove the cables.
Once the keyboard and trackpad are disconnected, the palmrest can be moved forward. If needed, a pry tool can be used.
With the keyboard and trackpad disconnected, disconnect the power button. Flip the black tab up and remove the palmrest.
Disconnect the flat flex cable over the hard drive. To do this, lift the black locking tab up and remove the cable from the ZIF socket.
To remove the hard drive, tilt it forward starting with the SATA interface. Once it is removed, set it aside as shown.
Disconnnect the drive cable. Wiggle the cable off until it is released. Do not forcefully remove the cable. Unserviced systems may be on tighter then a serviced one.
Remove the drive bumpers from the old drive. Transfer these to the new hard drive.
Once tested and reassembled, you will need to reinstall the operating system. This guide does not cover this step.
41 outras pessoas concluíram este guia.
27 comentários
Some hp pavilions you need to detach the keyboard first, then, and only then, can you access the screws that hold the palmrest!
This isn't the case on the P series. The keyboard is welded in with plastic so the top piece and keyboard is a singular component.
Nick -
Thanks, Nick. Great guide, took me about 20 mins to get this done.
That’s good to know. I said 2 hours to cover for users who will take a little longer to complete the repair. The difficulty also reflects on that.
Nick -
