Introdução
This repair guide was authored by the iFixit staff and hasn’t been endorsed by Google. Learn more about our repair guides here.
Follow this guide to replace a broken, cracked, or unresponsive screen on your Google Pixel 8a.
To calibrate the display’s fingerprint reader, follow this guide. Genuine Google replacement screens come with the fingerprint reader already attached. If your replacement screen doesn’t have a pre-installed fingerprint reader, you’ll need to transfer the original fingerprint reader to your new screen and recalibrate it to retain functionality.
You'll need replacement screen adhesives in order to complete this repair.
Note: Any repair can compromise the water resistance of your phone. Retaining water resistance after the repair will depend on how well you reapply the adhesive.
O que você precisa
Unplug all cables from your phone.
Completely power off your phone.
Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered.
Wear safety glasses to protect your eyes from any glass shaken free during the repair.
Use a hair dryer, heat gun, or hot plate to heat the top edge of the screen until it's almost too hot to touch.
Apply a suction handle to the center of the top edge of the screen.
Insert the tip of a Jimmy into the left side of the earpiece speaker cutout.
Pull up on the suction handle with a strong, steady force.
Firmly press the Jimmy into the cutout and lower it until the tip slides under the glass.
Slide your pick back and forth across the top edge of the screen to separate the adhesive.
Move the flap of graphite film away from the screen connector.
Use tweezers and a spudger to scrape up and remove any remaining pieces of adhesive below the battery cutout.
Use a pipette or syringe to apply a few drops of highly-concentrated isopropyl alcohol (over 90%) to the perimeter of the frame and the area below the battery cutout.
Wipe the residue away using a lint-free or microfiber cloth.
Peel the square piece of screen adhesive from its large liner.
Apply the adhesive to the frame in the same location as the old adhesive, just below the battery cutout.
Use your fingers to press down and secure the adhesive to the frame—don't remove the top liner yet.
Apply a suction handle to the left side of the replacement screen, with the handle facing left.
Prop up your screen on the left side of the frame.
Connect the screen cable by aligning it over the socket and pressing on one side until it clicks into place before fully pressing it down.
Now is a good time to test your phone before sealing it up. Power it on and check that it works. Power it back down before you continue reassembly.
Remove any liners from the front camera housing on the top edge of the screen.
Hold the screen just above the frame by the suction handle.
Use a spudger to fold the flap of graphite film back over the screen cable.
Press the screen into place.
To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
