Ir para o conteúdo principal
Google Pixel 3 Back Cover Adhesive Installation
O que você precisa
  1. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: passo 1, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: passo 1, imagem 2 %32 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the frame: passo 1, imagem 3 %32
    • Pick and scrape away the old adhesive from the frame.
    • Use a spudger to scrape away any lingering adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the frame.
    • For best results, clean the area underneath the removed adhesive with 90% or greater isopropyl alcohol to prep the surface for the new adhesive.
    Pergunte ao FixBot
    Comentar
  2. Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: passo 2, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: passo 2, imagem 2 %32 Google Pixel 3 Back Cover Adhesive Installation, Remove adhesive residue from the back cover: passo 2, imagem 3 %32
    • Repeat the previous step for the back cover adhesive.
    • Don't use metal tools to scrape away adhesive as this will damage the back cover coating.
    • Don't use isopropyl alcohol near the rear camera bracket as it will damage its adhesive and foam.
    Pergunte ao FixBot
    Comentar
  3. Google Pixel 3 Back Cover Adhesive Installation, Prepare the replacement adhesive: passo 3, imagem 1 %32
    • Peel away the clear plastic lining to expose the frame side of the replacement adhesive.
    Pergunte ao FixBot
    Comentar
  4. Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: passo 4, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Apply the adhesive: passo 4, imagem 2 %32
    • Be very careful during this step! The adhesive is very sticky and can't be repositioned once it sticks. Misaligned adhesive can lead to an improper seal.
    • Lower the adhesive onto the frame.
    • Use the rear camera and corners to properly align the adhesive.
    Pergunte ao FixBot
    Comentar
  5. Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: passo 5, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Secure the adhesive to the frame: passo 5, imagem 2 %32
    • Use the flat end of a spudger or your fingernail to press down on the adhesive.
    • Slide along the perimeter to secure the adhesive to the frame.
    Pergunte ao FixBot
    Comentar
  6. Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: passo 6, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Peel away the outer plastic lining: passo 6, imagem 2 %32
    • Peel away the blue outer plastic lining on the back cover side of the adhesive.
    Pergunte ao FixBot
    Comentar
  7. Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: passo 7, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Connect the fingerprint sensor cable: passo 7, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use tweezers or your fingers to position the fingerprint sensor cable over its connector on the motherboard.
    • Use the flat end of a spudger or your finger to press down on the connector to secure it to the motherboard.
    Pergunte ao FixBot
    Comentar
  8. Google Pixel 3 Back Cover Adhesive Installation: passo 8, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation: passo 8, imagem 2 %32 Google Pixel 3 Back Cover Adhesive Installation: passo 8, imagem 3 %32
    • Use tweezers or your fingers to place the bracket over the fingerprint sensor cable.
    Pergunte ao FixBot
    Comentar
  9. Google Pixel 3 Back Cover Adhesive Installation: passo 9, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation: passo 9, imagem 2 %32
    • Use a Phillips PH00 screwdriver to install the two 4.1 mm screws securing the bracket to the frame.
    Pergunte ao FixBot
    Comentar
  10. Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: passo 10, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Peel away the remaining plastic lining: passo 10, imagem 2 %32
    • Peel away the red plastic lining to expose the back cover side of the adhesive.
    Pergunte ao FixBot
    Comentar
  11. Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: passo 11, imagem 1 %32 Google Pixel 3 Back Cover Adhesive Installation, Secure the back cover to the frame: passo 11, imagem 2 %32
    • Lower the back cover onto the frame.
    • Press down on all edges of the back cover to secure it to the frame.
    • To help the adhesive bond more securely, heat the perimeter of the back cover and then place the phone face-down under a heavy stack of books for 30 minutes.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Pixel 3 Answers community for help.
11 outras pessoas executaram este guia.
Chayton Ritter
Membro desde: 08/21/20
26.963 Reputação
Autoria de 105 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 26
Últimos 30 dias: 79
Ao todo: 4,597
