Ir para o conteúdo principal
Garmin Vivoactive Display Unit Replacement
O que você precisa
    1. Garmin Vivoactive Display Unit Replacement, Wristband: passo 1, imagem 1 %32
      • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
      • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
      • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
      Pergunte ao FixBot
      Comentar
    2. Garmin Vivoactive Display Unit Replacement: passo 2, imagem 1 %32 Garmin Vivoactive Display Unit Replacement: passo 2, imagem 2 %32
      • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
      • Gently push the strap's pin out. It will begin to protrude from the other end.
      • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
      Pergunte ao FixBot
      Comentar
    1. Garmin Vivoactive Display Unit Replacement, Display Unit: passo 3, imagem 1 %32
      • Place a heated iOpener over the display to loosen the adhesive.
      • After about a minute, the iOpener may be removed.
      • For more in depth instructions on using the iOpener, refer to the iOpener guide.
      Pergunte ao FixBot
      Comentar
    2. Garmin Vivoactive Display Unit Replacement: passo 4, imagem 1 %32 Garmin Vivoactive Display Unit Replacement: passo 4, imagem 2 %32
      • Place the blue plastic opening tool in-between the screen and plastic casing of the watch and slowly pry up one side of the screen.
      Pergunte ao FixBot
      Comentar
    3. Garmin Vivoactive Display Unit Replacement: passo 5, imagem 1 %32
      • Once the first side has come free, wedge the blue pick in between the screen and watch unit on that side.
      • Complete one pass around the perimeter of the screen to break the adhesive bond on all four sides.
      • Insert it a minimal distance to avoid damaging internal components.
      Pergunte ao FixBot
      Comentar
    4. Garmin Vivoactive Display Unit Replacement: passo 6, imagem 1 %32
      • Use the blue plastic opening tool to pry up the side of the glass. Raise it to a point where your fingernail can fit in the gap.
      • Do the same on the opposite side of the device until you have a good grip of the screen.
      Pergunte ao FixBot
      Comentar
    5. Garmin Vivoactive Display Unit Replacement: passo 7, imagem 1 %32
      • Obtain a careful grip of the screen from two of its sides.
      • Slowly lift the screen off of the case. Separate it just enough so as not to damage the connection to the motherboard.
      Pergunte ao FixBot
      Comentar
    6. Garmin Vivoactive Display Unit Replacement: passo 8, imagem 1 %32
      • Detach the orange tab that connects the screen to the motherboard with a gentle uplift using a plastic opening tool.
      • Upon completing this step, the screen should be free from the rest of the device.
      Pergunte ao FixBot
      Comentar
Conclusão
16 outras pessoas executaram este guia.
Equipe
Cal Poly, Team 1-21, Maness Fall 2015 Membro de Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 Membros
Autoria de 21 guias
40Comentários do guia
Does anyone knows where can I buy a vivoactive display?
dragomariano - Responder Compartilhar
I need one vivoactive display too. If I can find how to find, I'll share it here.
erol - Responder Compartilhar
Did anyone ever find a location where you can order a replacement screen?
Dylan
dylanreynolds - Responder Compartilhar
Any links found for replacement screen?
dskggray - Responder Compartilhar
I've called Garmin support service but they said that displays units are not for sale from their side, only entire watch can be sold. I find it quite strange for not saying stupid because it's normal that using a watch displays can have a problem or that can be broken and easily fixed by replace them.
Being that said, if someone finds an alternative please share it, thanks
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 136
Ao todo: 105,329
