Ir para o conteúdo principal
Edifier W820NB Plus Drivers Replacement
O que você precisa
  1. Edifier W820NB Plus Drivers Replacement, Ear Pads: passo 1, imagem 1 %32
    • Start with the headphones face up and the earpads visible.
    Pergunte ao FixBot
    Comentar
  2. Edifier W820NB Plus Drivers Replacement: passo 2, imagem 1 %32 Edifier W820NB Plus Drivers Replacement: passo 2, imagem 2 %32
    • Hold the driver housing in one hand and insert an opening tool into the seam between the earpad and driver housing.
    Pergunte ao FixBot
    Comentar
  3. Edifier W820NB Plus Drivers Replacement: passo 3, imagem 1 %32 Edifier W820NB Plus Drivers Replacement: passo 3, imagem 2 %32
    • With your inserted opening tool, pry around the perimeter of the ear pad until it fully releases.
    • Repeat this procedure for the other side if necessary.
    Pergunte ao FixBot
    Comentar
  4. Edifier W820NB Plus Drivers Replacement: passo 4, imagem 1 %32
    • Repeat for the other side if necessary.
    Pergunte ao FixBot
    Comentar
  5. Edifier W820NB Plus Drivers Replacement, Drivers: passo 5, imagem 1 %32
    • Identify the driver you wish to replace.
    • This guide will use the left driver as an example but the same steps can be mirrored when replacing or removing the right driver. The battery is under the left driver, while the motherboard and daughterboard are under the right driver.
    Pergunte ao FixBot
    Comentar
  6. Edifier W820NB Plus Drivers Replacement: passo 6, imagem 1 %32 Edifier W820NB Plus Drivers Replacement: passo 6, imagem 2 %32
    • Remove all five 5 mm Phillips #0 screws that secure the driver assembly.
    Pergunte ao FixBot
    Comentar
  7. Edifier W820NB Plus Drivers Replacement: passo 7, imagem 1 %32 Edifier W820NB Plus Drivers Replacement: passo 7, imagem 2 %32 Edifier W820NB Plus Drivers Replacement: passo 7, imagem 3 %32
    • Note that the wires for the drivers are on the outermost edge. Try to avoid pushing or cutting them when taking the driver out.
    • Insert a Jimmy in the seam between the driver assembly and driver housing.
    • Rotate the Jimmy along the entire perimeter of the innermost edge to pry it out of place.
    Pergunte ao FixBot
    Comentar
  8. Edifier W820NB Plus Drivers Replacement: passo 8, imagem 1 %32 Edifier W820NB Plus Drivers Replacement: passo 8, imagem 2 %32
    • Gently remove the driver assembly from the rest of the headphone, with care not to strain the connected wire.
    Pergunte ao FixBot
    Comentar
  9. Edifier W820NB Plus Drivers Replacement: passo 9, imagem 1 %32 Edifier W820NB Plus Drivers Replacement: passo 9, imagem 2 %32
    • Skip this step if you are completing a battery replacement.
    • Repeat the procedure for the other driver if necessary.
    • Desolder the four driver connections from the motherboard.
    • Remove the driver assembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Happy Zhang
Membro desde: 03/21/25
438 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 42
Ao todo: 617
