Introdução
The circuit board of the device processes all logic and button input of the device. So if your Dirt Devil Scorpion Quick Flip fails to turn on or adjust speeds, it may point to an issue with the circuit board. If replacing the circuit board doesn’t solve the issue then try replacing Dirt Devil Scorpion Quick Flip Motor or Dirt Devil Scorpion Quick Flip Power Cord replacement guides. This guide will require soldering, so check out our How to Solder and Desolder Connections guide if you are unfamiliar with the process.
O que você precisa
Push the button on the left-hand side of the handle.
Remove the filter holder from the main body.
