Ir para o conteúdo principal
Dirt Devil Scorpion Quick Flip Power Cord Replacement
O que você precisa
  1. Dirt Devil Scorpion Quick Flip Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • While holding the device by the handle, press the button on the left-hand side of the vacuum handle in order to release the nozzle from the body.
  2. Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 2, imagem 1 %32 Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 2, imagem 2 %32
    • Using a Phillips #1 Screwdriver, remove all six of the 4 mm screws holding the shell together.
  3. Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 3, imagem 1 %32
    • Using utility scissors, cut the black and white cables approximately an inch and a half above where they connect to the faulty power cord.
  4. Dirt Devil Scorpion Quick Flip Power Cord Replacement: passo 4, imagem 1 %32
    • Using a soldering iron, fuse the black and white cables from the new power cord to where the previous cord was cut away.
    • Using electrical tape, cover the exposed area.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 305
