Ir para o conteúdo principal
Dirt Devil Scorpion Quick Flip Motor Replacement
O que você precisa
  1. Dirt Devil Scorpion Quick Flip Motor Replacement, Motor: passo 1, imagem 1 %32
    • Gently remove filter adapter from the vacuum body by pressing the gray plastic release button.
  2. Dirt Devil Scorpion Quick Flip Motor Replacement: passo 2, imagem 1 %32
    • Place the vacuum body on its left side and remove all 4mm screws with a Phillips #1 screwdriver.
  3. Dirt Devil Scorpion Quick Flip Motor Replacement: passo 3, imagem 1 %32
    • Carefully take apart the shell of the vacuum body.
    • Cut the two wires attached to the motor and remove the motor from the body.
  4. Dirt Devil Scorpion Quick Flip Motor Replacement: passo 4, imagem 1 %32
    • Solder the wires from the replacement motor to the wires connecting it to the power cord.
    • Carefully place the replacement motor back into its correct position in the vacuum body.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Duração total: 514
