Ir para o conteúdo principal
Dirt Devil Scorpion Quick Flip Circuit Board Replacement
O que você precisa
  1. Dirt Devil Scorpion Quick Flip Circuit Board Replacement, Circuit Board: passo 1, imagem 1 %32
    • Push the button on the left-hand side of the handle.
    • Remove the filter holder from the main body.
  2. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 2, imagem 1 %32 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 2, imagem 2 %32
    • Remove the first two 4 mm screws using a Phillips #1 Screwdriver.
    • Remove the last four 4 mm screws using a Phillips #1 Screwdriver.
    • Carefully take the device a part.
  3. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 3, imagem 1 %32 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 3, imagem 2 %32
    • Identify the circuit board located in the inside of the handle.
    • Remove the gray switch located on top of the circuit board.
    • Using utility scissors, cut the wires 1/2 inch away from the circuit board.
  4. Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 4, imagem 1 %32 Dirt Devil Scorpion Quick Flip Circuit Board Replacement: passo 4, imagem 2 %32
    • Solder the new circuit board to the existing wires.
    • Using electrical tape or heat shrink tubing, cover the soldered area.
    • Place the new circuit board into the correct spot inside the handle.
    • Check out our How to Solder and Desolder Connections guide if you are unfamiliar with the soldering process.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 138
