Ir para o conteúdo principal
Dell XPS 13 9300 Battery Replacement
O que você precisa
  1. Dell XPS 13 9300 Battery Replacement, Unfasten the lower case: passo 1, imagem 1 %32 Dell XPS 13 9300 Battery Replacement, Unfasten the lower case: passo 1, imagem 2 %32
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9300 Battery Replacement, Insert an opening pick: passo 2, imagem 1 %32 Dell XPS 13 9300 Battery Replacement, Insert an opening pick: passo 2, imagem 2 %32
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9300 Battery Replacement, Release the case's front clips: passo 3, imagem 1 %32 Dell XPS 13 9300 Battery Replacement, Release the case's front clips: passo 3, imagem 2 %32
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9300 Battery Replacement, Release the remaining clips: passo 4, imagem 1 %32 Dell XPS 13 9300 Battery Replacement, Release the remaining clips: passo 4, imagem 2 %32 Dell XPS 13 9300 Battery Replacement, Release the remaining clips: passo 4, imagem 3 %32
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9300 Battery Replacement: passo 5, imagem 1 %32 Dell XPS 13 9300 Battery Replacement: passo 5, imagem 2 %32 Dell XPS 13 9300 Battery Replacement: passo 5, imagem 3 %32
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  6. Dell XPS 13 9300 Battery Replacement, Disconnect the battery: passo 6, imagem 1 %32 Dell XPS 13 9300 Battery Replacement, Disconnect the battery: passo 6, imagem 2 %32 Dell XPS 13 9300 Battery Replacement, Disconnect the battery: passo 6, imagem 3 %32
    • Grip the pull tab on the battery connector with your fingers and gently pull away from the socket to disconnect it.
    • After you disconnect the battery, some of your laptop's startup (BIOS) settings will revert to their defaults.
    • You may need to run BIOS setup to reset the system clock as well as any specialized disk settings before you can boot up your XPS.
  7. Dell XPS 13 9300 Battery Replacement, Unfasten the battery: passo 7, imagem 1 %32
    • Use your Phillips screwdriver to remove the five 2.8 mm-long screws securing the battery.
  8. Dell XPS 13 9300 Battery Replacement, Remove the battery: passo 8, imagem 1 %32 Dell XPS 13 9300 Battery Replacement, Remove the battery: passo 8, imagem 2 %32
    • Remove the battery from its recess.
Conclusão
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS 13 9300 answers community for help.
4 outras pessoas executaram este guia.
Clay Eickemeyer
Membro desde: 09/19/22
70.408 Reputação
Autoria de 453 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 140
Autoria de 18.087 guias
5 comentários
ok - completed.
The only unexpected thing was upon restart. It did not boot up normally. Instead it gave a bios type warning message:
- Time of day not set - please run SETUP program
- Invalid configuration information - Please run SETUP program
So - I ran bios setup and managed to get to the place to change the time, applied the change, then it booted normally (typing from there now).
Not at all difficult, finishing in perhaps 15 minutes including the bios deal...
Tom - Responder
Same thing happened to me and fortunately Dell makes it really easy to get to the clock. Didn't have any issues.
Matt Anthony -
Thanks for bringing this up! I'll add a note in the conclusion for this.
Arthur Shi -
After replacing the battery, my XPS 9300 Ubuntu cannot find either HD or SSD. If you experience the same issue, it is because the default BIOS setting for RAID may be wrong. After losing power, it goes back to a wrong setting. So make sure you choose the right RAID setting after battery change.
Ziming Zhao - Responder
Great guide, nice and easy, and indeed, 15–30 minutes.
A suggestion on opening with picks: the corner is not always the best place to start; it could be easier to insert a pick first somewhere else on the edge, just not in the hinge area.
Another thing is to be careful around the front LED indicator; it's easy to slip a pick under it, and that is not helpful for opening the laptop case. Just don't do that.
And for screws, they are finger tight, very easy to strip if you're holding the screwdriver stronger, then with just a two-finger pinch. It's a good idea to use some blue loctite instead of trying to torque it all the way (the manufacturer uses loctite too, at least for the battery screws).
Evgeny Stepanov - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 35
Últimos 30 dias: 232
Duração total: 11,840
