Ir para o conteúdo principal
CAT S22 Flip Battery Replacement
O que você precisa
  1. CAT S22 Flip Battery Replacement, Battery: passo 1, imagem 1 %32
    • Unscrew the large screw on the back of the phone using a flathead screwdriver or coin.
    • The screw will always be completely unscrewed after 4 full counter-clockwise rotations.
    • The screw cannot be completely removed so that you can’t lose the screw.
    Pergunte ao FixBot
    Comentar
  2. CAT S22 Flip Battery Replacement: passo 2, imagem 1 %32
    • There is a slot on the upper left side of the back plate to insert the Spudger.
    • Use a spudger to pry up the back plate.
    Pergunte ao FixBot
    Comentar
  3. CAT S22 Flip Battery Replacement: passo 3, imagem 1 %32
    • There is a slot to insert a spudger at the bottom of the battery.
    • Use a spudger to lift the battery out of the phone.
    • Do not operate on a devise with a swollen battery. Do not dispose of a swollen battery into general waste systems. You can dispose of the batteries with a qualified technician or facility.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 12
Últimos 30 dias: 44
Ao todo: 234
