Ir para o conteúdo principal
Blackberry PRIV Battery Replacement
O que você precisa
  1. Blackberry PRIV Battery Replacement, Rear Casing: passo 1, imagem 1 %32 Blackberry PRIV Battery Replacement, Rear Casing: passo 1, imagem 2 %32 Blackberry PRIV Battery Replacement, Rear Casing: passo 1, imagem 3 %32
    • Look for the two small holes at the top of your device.
    • Use a SIM eject tool to push down into the holes which lifts the SIM and SD trays.
    • Pull the trays up and out of the device.
    Pergunte ao FixBot
    Comentar
  2. Blackberry PRIV Battery Replacement: passo 2, imagem 1 %32 Blackberry PRIV Battery Replacement: passo 2, imagem 2 %32 Blackberry PRIV Battery Replacement: passo 2, imagem 3 %32
    • Insert an opening pick in the seam between the rear casing and chassis. Apply downward pressure to pry the casing upward.
    • Follow this procedure for only the right, left, and top side of the casing.
    Pergunte ao FixBot
    Comentar
  3. Blackberry PRIV Battery Replacement: passo 3, imagem 1 %32 Blackberry PRIV Battery Replacement: passo 3, imagem 2 %32 Blackberry PRIV Battery Replacement: passo 3, imagem 3 %32
    • Remove the rear casing by sliding the case down and out.
    Pergunte ao FixBot
    Comentar
  4. Blackberry PRIV Battery Replacement, Battery: passo 4, imagem 1 %32 Blackberry PRIV Battery Replacement, Battery: passo 4, imagem 2 %32
    • Remove the two 3.3 mm T4 Torx screws that secure the battery connector.
    • There may be a plastic protector covering the circuit board and battery. Remove the plastic protector to begin.
    Pergunte ao FixBot
    Comentar
  5. Blackberry PRIV Battery Replacement: passo 5, imagem 1 %32 Blackberry PRIV Battery Replacement: passo 5, imagem 2 %32
    • Use an opening tool to lift and disconnect the battery connector.
    Pergunte ao FixBot
    Comentar
  6. Blackberry PRIV Battery Replacement: passo 6, imagem 1 %32 Blackberry PRIV Battery Replacement: passo 6, imagem 2 %32 Blackberry PRIV Battery Replacement: passo 6, imagem 3 %32
    • Pull on the plastic tab to remove the battery from the device.
    • For easier removal, use a blow dryer to warm the battery glue.
    • Be careful to not overheat the battery or puncture the battery as lithium batteries are dangerous.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Benjamin Olvera
Membro desde: 09/25/24
563 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 15
Últimos 30 dias: 93
Ao todo: 953
