Ir para o conteúdo principal
Beats Studio 2 Wireless Bluetooth Board Replacement
O que você precisa
  1. Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: passo 1, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement, Ear Cushion: passo 1, imagem 2 %32
    • Insert a spudger between the plastic part of the left headphone and the ear cushion.
    • Work the spudger around the periphery of the base of the cushion and gently pry it off the head phone.
    Pergunte ao FixBot
    Comentar
  2. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 2, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement: passo 2, imagem 2 %32 Beats Studio 2 Wireless Bluetooth Board Replacement: passo 2, imagem 3 %32
    • Pull the rest of the cushion away from the adhesive with your hands.
    Pergunte ao FixBot
    Comentar
  3. Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: passo 3, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement, Speaker: passo 3, imagem 2 %32
    • Using the Phillips #00 screwdriver, remove the screws holding the speaker in place.
    • If the speaker is on the side with the charging port be sure to keep the two screws holding the charging port separate.
    Pergunte ao FixBot
    Comentar
  4. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 4, imagem 1 %32
    • Gently separate the speaker from the headphones.
    • Don't pull or yank the speaker from the headphones. They are connected together by wires that might be damaged.
    Pergunte ao FixBot
    Comentar
  5. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 5, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement: passo 5, imagem 2 %32
    • Gently pull the wire with rubber connectors off of the speaker.
    Pergunte ao FixBot
    Comentar
  6. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 6, imagem 1 %32
    • Use a soldering iron to desolder the two connections.
    • For details on how to solder and desolder, refer to the How to Solder and Desolder Connections guide.
    • A soldering iron can produce very high temperatures, and can burn skin. Use with caution.
    • Note the position of the speaker in its housing, then carefully remove the faulty speaker.
    Pergunte ao FixBot
    Comentar
  7. Beats Studio 2 Wireless Bluetooth Board Replacement, Bluetooth Board: passo 7, imagem 1 %32
    • Peel off the sticker underneath the speaker.
    Pergunte ao FixBot
    Comentar
  8. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 8, imagem 1 %32
    • Remove the center screw using a Phillips #00 screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 9, imagem 1 %32
    • Separate the plastic case from the rubber backing by hand or with a spudger.
    Pergunte ao FixBot
    Comentar
  10. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 10, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement: passo 10, imagem 2 %32
    • Use a Phillips #00 to remove the four screws securing the case on top of the Bluetooth board.
    Pergunte ao FixBot
    Comentar
  11. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 11, imagem 1 %32
    • Use a spudger to gently pry the left headband clip to free the earphone from the hinge.
    • This picture shows this for the right earphone, but the process should be exactly the same for the left side.
    Pergunte ao FixBot
    Comentar
  12. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 12, imagem 1 %32
    • Slide the front case down to separate it from the back and reveal the Bluetooth board.
    Pergunte ao FixBot
    Comentar
  13. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 13, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement: passo 13, imagem 2 %32
    • Remove the four screws from the Bluetooth board with the Phillips #00 screwdriver.
    • This will free the Bluetooth board from the back case.
    Pergunte ao FixBot
    Comentar
  14. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 14, imagem 1 %32 Beats Studio 2 Wireless Bluetooth Board Replacement: passo 14, imagem 2 %32
    • Remove the Bluetooth board from the case.
    • Remove the translucent sticker from the back of the Bluetooth board.
    Pergunte ao FixBot
    Comentar
  15. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 15, imagem 1 %32
    • Use the pointed tip of a spudger to carefully push on each side of the connector to remove it from the socket.
    Pergunte ao FixBot
    Comentar
  16. Beats Studio 2 Wireless Bluetooth Board Replacement: passo 16, imagem 1 %32
    • Desolder the RYB connectors, and the connector attached to the black wire using a soldering iron.
    • For information on desoldering connections, see the How to Solder and Desolder Connections Guide.
    • The soldering iron can reach very high temperatures. Use it with caution.
    Pergunte ao FixBot
    Comentar
Conclusão
3 outras pessoas executaram este guia.
Jack Wilson
Membro desde: 03/20/23
581 Reputação
Autoria de 2 guias
Equipe
1Comentário do guia
Hi, can you help me out with a wiring diagram to the bluetooth board, all my wires got torn loose from my old board and i do not know where to solder the new wires to which connections. If you could post a picture with which coloured wires go where , that would be most helpful, thanks.
Roger Bee_44 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 79
Ao todo: 2,906
