Ir para o conteúdo principal
Battery Disconnection
O que você precisa
  1. Battery Disconnection, Safety precautions: passo 1, imagem 1 %32 Battery Disconnection, Safety precautions: passo 1, imagem 2 %32
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
    Pergunte ao FixBot
  2. Battery Disconnection, Screen removal information: passo 2, imagem 1 %32 Battery Disconnection, Screen removal information: passo 2, imagem 2 %32 Battery Disconnection, Screen removal information: passo 2, imagem 3 %32
    • The screen of the Google Pixel 7 Pro is held in place by plastic clips and adhesive. Note the following:
    • Screen seam: This seam separates the screen from the rest of the phone. Do not pry at this seam.
    • Bezel seam: This is where the plastic bezel designed to protect the screen meets the frame. It's held in place by plastic clips. This is where you should pry.
    • During the removal procedure, make sure to insert your opening picks in the right position to avoid separating the screen from its safety frame.
    • Only insert the pick up to ~3.5 mm during the removal procedure to avoid damaging the internals and to avoid interfering with the plastic clips.
    • There are several plastic clips around the whole screen. If your opening pick gets blocked during the screen removal procedure, you've inserted your pick too deep underneath the screen.
    Pergunte ao FixBot
  3. Battery Disconnection, Anti-Clamp instructions: passo 3, imagem 1 %32 Battery Disconnection, Anti-Clamp instructions: passo 3, imagem 2 %32 Battery Disconnection, Anti-Clamp instructions: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    Clampy - Anti-Clamp
    $24.95
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
    Pergunte ao FixBot
  4. Battery Disconnection: passo 4, imagem 1 %32 Battery Disconnection: passo 4, imagem 2 %32 Battery Disconnection: passo 4, imagem 3 %32
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
    Pergunte ao FixBot
  5. Battery Disconnection: passo 5, imagem 1 %32 Battery Disconnection: passo 5, imagem 2 %32 Battery Disconnection: passo 5, imagem 3 %32
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
    Pergunte ao FixBot
  6. Battery Disconnection, Loosen the display adhesive: passo 6, imagem 1 %32
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device. The edge should feel slightly too hot to the touch.
    Pergunte ao FixBot
  7. Battery Disconnection, Insert an opening pick: passo 7, imagem 1 %32 Battery Disconnection, Insert an opening pick: passo 7, imagem 2 %32 Battery Disconnection, Insert an opening pick: passo 7, imagem 3 %32
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your display is badly cracked, covering it with a layer of clear packing tape may allow the suction cup to adhere. Alternatively, very strong tape may be used instead of the suction cup. If all else fails, you can superglue the suction cup to the broken screen.
    • Lift the screen including its safety frame with the suction handle to create a small gap between the screen and the phone assembly.
    • Depending on the age of your phone, this may be difficult. If you're having trouble, apply more heat to the bottom edge and try again.
    • Insert an opening pick into the gap.
    Pergunte ao FixBot
  8. Battery Disconnection, Prevent damage to your phone: passo 8, imagem 1 %32 Battery Disconnection, Prevent damage to your phone: passo 8, imagem 2 %32
    • To avoid damaging your phone, don't insert your pick more than ~2.5 mm as you separate the screen adhesive. Note the following areas:
    • The screen cable is a little less than halfway up the left edge of the phone. Be very careful here to avoid tearing the cable.
    • There are many spring contacts around the perimeter of the phone. Be very careful in these areas to avoid bending the contacts.
    Pergunte ao FixBot
  9. Battery Disconnection, Slice the bottom edge adhesive: passo 9, imagem 1 %32 Battery Disconnection, Slice the bottom edge adhesive: passo 9, imagem 2 %32
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
    Pergunte ao FixBot
  10. Battery Disconnection: passo 10, imagem 1 %32 Battery Disconnection: passo 10, imagem 2 %32
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
    • There's a plastic clip in the bottom left corner that will block your opening pick. Only use the tip of the opening pick (~1 mm) to work your way around it.
    Pergunte ao FixBot
  11. Battery Disconnection, Release the left clips: passo 11, imagem 1 %32 Battery Disconnection, Release the left clips: passo 11, imagem 2 %32 Battery Disconnection, Release the left clips: passo 11, imagem 3 %32
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive and to release the plastic clips.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
  12. Battery Disconnection, Slice the top edge adhesive: passo 12, imagem 1 %32 Battery Disconnection, Slice the top edge adhesive: passo 12, imagem 2 %32 Battery Disconnection, Slice the top edge adhesive: passo 12, imagem 3 %32
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (~2.5 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
    Pergunte ao FixBot
  13. Battery Disconnection, Release the right clips: passo 13, imagem 1 %32 Battery Disconnection, Release the right clips: passo 13, imagem 2 %32 Battery Disconnection, Release the right clips: passo 13, imagem 3 %32
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive and release the right plastic clips.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly by a flex cable.
    Pergunte ao FixBot
  14. Battery Disconnection, Open up the phone: passo 14, imagem 1 %32 Battery Disconnection, Open up the phone: passo 14, imagem 2 %32 Battery Disconnection, Open up the phone: passo 14, imagem 3 %32
    • Lift the right edge of the screen up and towards the left side of the device, like opening a book.
    • Don't twist the screen or move it too far away from the frame to avoid straining or damaging the flex cable.
    • Rest the screen upside down and parallel to the frame.
    Pergunte ao FixBot
  15. Battery Disconnection, Release the display cable bracket: passo 15, imagem 1 %32 Battery Disconnection, Release the display cable bracket: passo 15, imagem 2 %32
    • The display cable bracket sits tightly and requires some force to release it.
    • Insert one arm of a pair of tweezers into the opening at the upper end of the display cable bracket.
    • Push the bracket inwards and pry up to release it.
    Pergunte ao FixBot
  16. Battery Disconnection, Remove the display cable bracket: passo 16, imagem 1 %32 Battery Disconnection, Remove the display cable bracket: passo 16, imagem 2 %32 Battery Disconnection, Remove the display cable bracket: passo 16, imagem 3 %32
    • Use a pair of tweezers to remove the display cable bracket by pulling it from underneath the midframe and in direction of the camera.
    Pergunte ao FixBot
  17. Battery Disconnection, Disconnect the display cable: passo 17, imagem 1 %32 Battery Disconnection, Disconnect the display cable: passo 17, imagem 2 %32
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    Pergunte ao FixBot
  18. Battery Disconnection, Screen information: passo 18, imagem 1 %32
    • The back of the Pixel's screen is very fragile. Even a small scratch or dent can damage the screen.
    • To prevent damaging your screen or replacement screen:
    • When handling your screen, grip it by its edges.
    • When placing the screen on your work area, make sure nothing is touching the bottom of the screen. Consider placing it on a soft, lint-free cloth.
    Pergunte ao FixBot
  19. Battery Disconnection, Peel off the graphite foil: passo 19, imagem 1 %32 Battery Disconnection, Peel off the graphite foil: passo 19, imagem 2 %32 Battery Disconnection, Peel off the graphite foil: passo 19, imagem 3 %32
    • Use a pair of tweezers to carefully peel the graphite foil off the battery and midframe.
    • Take care not to puncture or bend the battery with your tool—a punctured or bent battery may leak dangerous chemicals or cause a fire.
    • If you're having a hard time peeling off the foil, you can apply a heated iOpener to the back of the device for two minutes to loosen its adhesive.
    Pergunte ao FixBot
  20. Battery Disconnection, Unfasten the charging port bracket screws: passo 20, imagem 1 %32 Battery Disconnection, Unfasten the charging port bracket screws: passo 20, imagem 2 %32
    • Use a Torx T3 screwdriver to remove the two 5.1 mm-long screws securing the charging port bracket.
    Pergunte ao FixBot
  21. Battery Disconnection, Remove the charging port bracket: passo 21, imagem 1 %32 Battery Disconnection, Remove the charging port bracket: passo 21, imagem 2 %32
    • Use a pair of tweezers to remove the charging port bracket.
    Pergunte ao FixBot
  22. Battery Disconnection, Unfasten the midframe screws: passo 22, imagem 1 %32 Battery Disconnection, Unfasten the midframe screws: passo 22, imagem 2 %32
    • Use a Torx T3 screwdriver to remove the six 5.1 mm-long screws securing the midframe.
    Pergunte ao FixBot
  23. Battery Disconnection, Remove the midframe: passo 23, imagem 1 %32 Battery Disconnection, Remove the midframe: passo 23, imagem 2 %32 Battery Disconnection, Remove the midframe: passo 23, imagem 3 %32
    • Use a pair of tweezers to remove the midframe.
    • During reassembly check the condition of the thermal pad. If it's damaged, remove the pad, clean the area with high-concentration (greater than 90%) isopropyl alcohol and a microfiber or lint-free cloth, and apply a new thermal pad.
    Pergunte ao FixBot
  24. Battery Disconnection, Disconnect the battery cable: passo 24, imagem 1 %32 Battery Disconnection, Disconnect the battery cable: passo 24, imagem 2 %32
    • Use a spudger to disconnect the battery cable by prying the connector straight up from its socket.
    Pergunte ao FixBot
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Google Pixel 7 Pro answers community for help.
3 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
258.612 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.721 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 25
Últimos 30 dias: 169
Ao todo: 2,872
