Ir para o conteúdo principal
Asus ROG G20CB RAM Replacement
O que você precisa
    1. Asus ROG G20CB  RAM Replacement, Fan: passo 1, imagem 1 %32 Asus ROG G20CB  RAM Replacement, Fan: passo 1, imagem 2 %32
      • Remove each of the two 4.6 mm Phillips screws on the top and bottom of the tower.
      Pergunte ao FixBot
      Comentar
    2. Asus ROG G20CB  RAM Replacement: passo 2, imagem 1 %32
      • Slide the front panel to the left and lift gently.
      • There is a cable connecting the panel to the computer. Handle it gently and avoid straining the connected panel.
      Pergunte ao FixBot
      Comentar
    3. Asus ROG G20CB  RAM Replacement: passo 3, imagem 1 %32
      • Disconnect the cable carefully by pulling gently on both sides of the connector.
      Pergunte ao FixBot
      Comentar
    4. Asus ROG G20CB  RAM Replacement: passo 4, imagem 1 %32
      • Remove the five 4.6 mm Phillips screws holding down the fan tray and then pull the fan tray out of the system.
      • The fans are connected by a thin cable, be gentle when removing tray.
      Pergunte ao FixBot
      Comentar
    5. Asus ROG G20CB  RAM Replacement: passo 5, imagem 1 %32
      • Carefully unplug the two fan cables from the motherboard by pulling straight up from the base of the connector.
      Pergunte ao FixBot
      Comentar
    6. Asus ROG G20CB  RAM Replacement: passo 6, imagem 1 %32
      • Remove the six 4.6 mm Phillips screws connecting the fans to the fan tray.
      Pergunte ao FixBot
      Comentar
    1. Asus ROG G20CB  RAM Replacement, CPU Cooler: passo 7, imagem 1 %32
      • Remove the 4.6 mm Phillips screw that secures the optical drive.
      Pergunte ao FixBot
      Comentar
    2. Asus ROG G20CB  RAM Replacement: passo 8, imagem 1 %32
      • Push the optical drive out of the chassis.
      Pergunte ao FixBot
      Comentar
    3. Asus ROG G20CB  RAM Replacement: passo 9, imagem 1 %32
      • Pull back the tape on the heat sink and use a long-neck Phillips screwdriver to remove the four screws securing the heat sink.
      • There is a number next to each screw, when taking the cooler off, loosen in descending order (4-3-2-1). When installing a cooler, tighten in ascending order.
      Pergunte ao FixBot
      Comentar
    4. Asus ROG G20CB  RAM Replacement: passo 10, imagem 1 %32
      • Remove the 4.6 mm Phillips screw from the heatsink at the top of the case.
      • Lift the CPU cooler out of the system.
      • Be sure to apply fresh thermal paste before reinstalling a cooler.
      Pergunte ao FixBot
      Comentar
    1. Asus ROG G20CB  RAM Replacement, RAM: passo 11, imagem 1 %32
      • Gently push outward on the two retaining clips on either side of the RAM stick.
      Pergunte ao FixBot
      Comentar
    2. Asus ROG G20CB  RAM Replacement: passo 12, imagem 1 %32
      • The RAM module should pop up at an angle.
      • Pull the RAM stick out carefully by grasping it by the edges.
      • Avoid touching gold contacts.
      Pergunte ao FixBot
      Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Kimber-Starr
Membro desde: 03/21/25
361 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 18
Últimos 30 dias: 47
Ao todo: 663
