Ir para o conteúdo principal
Anker SoundCore 2 Bluetooth Chip Replacement
O que você precisa
  1. Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: passo 1, imagem 1 %32 Anker SoundCore 2 Bluetooth Chip Replacement, Front Panel: passo 1, imagem 2 %32
    • Insert a spudger between the front panel and the body of the speaker.
    • Pry around the edges of the front panel with the spudger to pry it away from the speaker body.
    Pergunte ao FixBot
    Comentar
  2. Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: passo 2, imagem 1 %32 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: passo 2, imagem 2 %32 Anker SoundCore 2 Bluetooth Chip Replacement, Motherboard: passo 2, imagem 3 %32
    • Remove eight 10 mm screws from the speaker mount using a Phillips #0 screwdriver.
    • Insert a spudger in the gap between the speaker mount and speaker body to remove the speaker mount.
    • Use your hand to remove the speakers.
    Pergunte ao FixBot
    Comentar
  3. Anker SoundCore 2 Bluetooth Chip Replacement: passo 3, imagem 1 %32 Anker SoundCore 2 Bluetooth Chip Replacement: passo 3, imagem 2 %32 Anker SoundCore 2 Bluetooth Chip Replacement: passo 3, imagem 3 %32
    • Remove the 10 mm screw that is holding the motherboard in place using a Phillips #0 screwdriver.
    • Flip up the motherboard and disconnect the cord that connects the motherboard and the battery.
    Pergunte ao FixBot
    Comentar
  4. Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: passo 4, imagem 1 %32 Anker SoundCore 2 Bluetooth Chip Replacement, Bluetooth Chip: passo 4, imagem 2 %32
    • Desolder the bluetooth chip and solder a new one on the motherboard where the existing one was.
    • For help desoldering and soldering, follow this guide.
    Pergunte ao FixBot
    Comentar
Conclusão
1Comentário do guia
My soundcore 2 will randomly peak in volume. It gets louder and then goes back to normal in random short bursts.
foxknight19 - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 77
Ao todo: 2,944
