Ir para o conteúdo principal
Amazon Kindle 8 Battery Replacement
O que você precisa
  1. Amazon Kindle 8 Battery Replacement, Front Cover: passo 1, imagem 1 %32 Amazon Kindle 8 Battery Replacement, Front Cover: passo 1, imagem 2 %32
    • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
    • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
    • Keep even pressure to avoid any cracks.
    • Lift front cover once all clips are disengaged.
    • Lift the front cover gently so that it is not cracked.
    Pergunte ao FixBot
    Comentar
  2. Amazon Kindle 8 Battery Replacement: passo 2, imagem 1 %32 Amazon Kindle 8 Battery Replacement: passo 2, imagem 2 %32
    • Insert the spudger between the inner front cover and the screen.
    • Gently work your way around to loosen the inner front cover.
    • Carefully lift the inner front cover from the device.
    Pergunte ao FixBot
    Comentar
  3. Amazon Kindle 8 Battery Replacement, Motherboard: passo 3, imagem 1 %32 Amazon Kindle 8 Battery Replacement, Motherboard: passo 3, imagem 2 %32
    • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
    Pergunte ao FixBot
    Comentar
  4. Amazon Kindle 8 Battery Replacement: passo 4, imagem 1 %32 Amazon Kindle 8 Battery Replacement: passo 4, imagem 2 %32
    • Lift the screen and motherboard from the back cover.
    Pergunte ao FixBot
    Comentar
  5. Amazon Kindle 8 Battery Replacement, Battery: passo 5, imagem 1 %32
    • Pinch the clips on the battery and disconnect the battery connector from its socket.
    Pergunte ao FixBot
    Comentar
  6. Amazon Kindle 8 Battery Replacement: passo 6, imagem 1 %32
    • Insert the halberd spudger between the motherboard and battery.
    • Take care not to bend, twist, or puncture the battery.
    • Slowly move the spudger around the battery and pry it off.
    • The battery is glued in place, so don't be afraid to use some moderate force.
    Pergunte ao FixBot
    Comentar
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
Membro desde: 09/25/24
444 Reputação
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 17
Últimos 7 dias: 76
Últimos 30 dias: 344
Ao todo: 5,831
