Ir para o conteúdo principal
8BitDo Ultimate Wireless Joystick Module Replacement
O que você precisa
  1. 8BitDo Ultimate Wireless Joystick Module Replacement, Case: passo 1, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement, Case: passo 1, imagem 2 %32
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Pergunte ao FixBot
  2. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 2, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 2, imagem 2 %32
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Pergunte ao FixBot
  3. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 3, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 3, imagem 2 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 3, imagem 3 %32
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Pergunte ao FixBot
  4. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 4, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 4, imagem 2 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 4, imagem 3 %32
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Pergunte ao FixBot
  5. 8BitDo Ultimate Wireless Joystick Module Replacement, Joystick's Module: passo 5, imagem 1 %32
    • Grip each analog stick cap firmly and pull straight up to remove them.
    Pergunte ao FixBot
  6. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 6, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 6, imagem 2 %32
    • Remove the three 5 mm Phillips #00 screws securing the midframe to the back shell, then lift it straight out.
    Pergunte ao FixBot
  7. 8BitDo Ultimate Wireless Joystick Module Replacement: passo 7, imagem 1 %32 8BitDo Ultimate Wireless Joystick Module Replacement: passo 7, imagem 2 %32
    • Turn to the backside of the circuit board for clear access to the solder joints.
    • Desolder all of the outlined solder joints.
    • Refer to the following solder guide if necessary: How To Solder and Desolder Connections
    Pergunte ao FixBot
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Alexander Garcia
Membro desde: 04/03/26
473 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 13
Últimos 30 dias: 31
Ao todo: 70
