Ir para o conteúdo principal
8BitDo Ultimate Wireless D-Pad Replacement
O que você precisa
  1. 8BitDo Ultimate Wireless D-Pad Replacement, Case: passo 1, imagem 1 %32 8BitDo Ultimate Wireless D-Pad Replacement, Case: passo 1, imagem 2 %32
    • Insert an opening pick into the seam between the left controller grip and main controller body.
    • Pry the grip off.
    • Repeat for the right grip.
    Pergunte ao FixBot
    Comentar
  2. 8BitDo Ultimate Wireless D-Pad Replacement: passo 2, imagem 1 %32 8BitDo Ultimate Wireless D-Pad Replacement: passo 2, imagem 2 %32
    • Remove the six 8 mm T6 Torx screws securing the rear case to the front case.
    Pergunte ao FixBot
    Comentar
  3. 8BitDo Ultimate Wireless D-Pad Replacement: passo 3, imagem 1 %32 8BitDo Ultimate Wireless D-Pad Replacement: passo 3, imagem 2 %32 8BitDo Ultimate Wireless D-Pad Replacement: passo 3, imagem 3 %32
    • Insert an opening tool into seam at the bottom of the device and carefully pry the front and back shells apart.
    • Set the halves next to each other with care not to strain the connected ribbon cables.
    Pergunte ao FixBot
    Comentar
  4. 8BitDo Ultimate Wireless D-Pad Replacement: passo 4, imagem 1 %32 8BitDo Ultimate Wireless D-Pad Replacement: passo 4, imagem 2 %32 8BitDo Ultimate Wireless D-Pad Replacement: passo 4, imagem 3 %32
    • The ribbon cable is secured with a locking tab connector.
    • Use tweezers to unlock the locking tab on the ribbon cable connector, then gently disconnect the ribbon cable.
    Pergunte ao FixBot
    Comentar
  5. 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: passo 5, imagem 1 %32 8BitDo Ultimate Wireless D-Pad Replacement, D-Pad: passo 5, imagem 2 %32
    • Remove the seven 5 mm Phillips #00 screws securing the PCB to the top shell, then lift the board out.
    Pergunte ao FixBot
    Comentar
  6. 8BitDo Ultimate Wireless D-Pad Replacement: passo 6, imagem 1 %32
    • Carefully lift the D-pad conductive pad out of the shell.
    Pergunte ao FixBot
    Comentar
  7. 8BitDo Ultimate Wireless D-Pad Replacement: passo 7, imagem 1 %32 8BitDo Ultimate Wireless D-Pad Replacement: passo 7, imagem 2 %32
    • Remove the directional pad.
    Pergunte ao FixBot
    Comentar
Conclusão
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Uma outra pessoa concluiu este guia.
Alexander Garcia
Membro desde: 04/03/26
473 Reputação
Autoria de 4 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 110
