Como para de pingar
A torneira está a pingar
Esta é uma boa pergunta?
@joaoleite19461 we will need to know the exact model of your tap. Common issues with the Grohe taps are limescale or grit buildup as well as cracked bottom O-rings.
In general, to disassemble the tap, you usually just have to remove a small Allen screw to remove the handle ( it maybe covered with a plug that you need to remove first). If mineral buildup has it stuck, wiggle it gently as you pull it up. With the handle removed you will have access to the ceramic cartridge that Grohe uses. Now you either need an adjustable wrench or a 30mm socked to remove the cartridge. Check for any other debris etc. It is best to replace the cartridge but you can try and clean it. MAKE SURE YOU TURN THE HOT AND COLD WATER SUPPLY LINES OFF :-)
These are very general instructions and it will depend on the exact model of your Grohe tap. Take plenty of pictures so we can see what you see and hopefully can get your dripping faucet repaired.
While you work on your faucet, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@joaoleite19461, vamos precisar de saber o modelo exato da tua torneira. Os problemas mais comuns nas torneiras Grohe são a acumulação de calcário ou de resíduos, bem como anéis de vedação inferiores rachados.
Em geral, para desmontar a torneira, basta remover um pequeno parafuso Allen para retirar o manípulo (pode estar coberto por um tampão que tens de remover primeiro). Se o acúmulo de minerais o tiver encravado, mexe-o suavemente enquanto o puxas para cima. Com o manípulo removido, terás acesso ao cartucho cerâmico que a Grohe utiliza. Agora, vais precisar de uma chave inglesa ou de uma chave de soquete de 30 mm para remover o cartucho. Verifica se há outros resíduos, etc. O melhor é substituir o cartucho, mas podes tentar limpá-lo. NÃO TE ESQUECAS DE FECHAR AS LINHAS DE ABASTECIMENTO DE ÁGUA QUENTE E FRIA :-)
Estas são instruções muito gerais e vão depender do modelo exato da tua torneira Grohe. Tira muitas fotos para que possamos ver o que estás a ver e, com sorte, consigamos reparar a tua torneira a pingar. Adicionar imagens a uma pergunta já existente
Enquanto estiveres a trabalhar na tua torneira, tira muitas fotos. Quando terminares, usa essas fotos para criar um guia para o iFixit. Isso vai ajudar a próxima pessoa que tiver os mesmos problemas com o seu dispositivo. É fácil e divertido criar estes guias. https://pt.ifixit.com/Guide/new A comunidade do iFixit vai ficar muito grata por isso.
A reparação é a guerra contra a entropia!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 9
Ao todo: 9
