I think dpf block
Hi just bought Mazda cx 5 2013 diesel when I drive on motorway it’s loose power stick 30 35 mph and missing but still drive what’s the main issue please explain thank you
Esta é uma boa pergunta?
@jagjeetsin59308 the symptoms you are describing, sudden power loss and restricting your speed to 30-35 mph, means your Mazda has entered "Limp Mode." The engine's computer does this intentionally to protect the engine from further damage when it detects a major fault. There are a few things that can cause this and it'll be a lot of guessing and a lot work and parts ($$$) on our side. Yes, it could be the DPF but it can also be caused by carbon buildup on the EGR valve as well as a worn camshaft etc. Start by scanning OBD2 Diagnostic Trouble Codes and let us know which code you get.
Esta resposta foi útil?
Thank you oldturkey03
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 55
Ao todo: 55
