The vibration function is not working
Esta é uma boa pergunta?
@volkankarasay first check what Realme suggest:
Check Sound and Vibration Settings
Next check this:
Finally run the hardware diagnostics test:
If the failure is not related to any of your settings, you may have a failed vibrator motor and will need to replace it. Since iFixit does not yet have a specific guide for this, use something like this video at the end of the video you see the vibrator on the bottom right side. You do not have to remove the screen or even to main board. You should get to the vibrator by removing the speaker and the charging board.
Esta resposta foi útil?
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 37
Ao todo: 37
