Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
Can you change the screen of a 3DS?
The right side portion of my top screen is black and has a small crack. How and where can I fix it?
Esta é uma boa pergunta?
Pontuação 3
5 comentários
there thoughts are wroung!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
por
how can i fix my screen that has a crack in it
por
the screen im talking about is the 3ds
por
theres aproblem with it ???????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????????
por
Adicionar um comentário
3 respostas
Pergunta mais útil
alexia munguia, you can fix it by following this guide. If you want to get it fixed, you'd better Google for a service that is close to your geographic location. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 2
Yes, I agree with Old Turkey, just follow that guide and use the tools you need. If you really are going to fix it yourself, here's a top screen replacement that you can buy: http://www.ebay.com/itm/Top-Upper-Replac...
Pontuação 1
yes
Pontuação 0
Adicionar a sua resposta
alexia munguia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 9,939
