Ir para o conteúdo principal
O smartphone topo de linha da Apple para 2021. Lançado em 24 de setembro, o iPhone 13 Pro Max possui uma tela OLED ProMotion de 6,7 polegadas, um novo sistema de câmera traseira tripla e conectividade 5G. Sucessor do iPhone 12 Pro Max.
Please help back glass replacement
I was replacing the back glass on an iPhone 13 Pro Max and a piece to the right of the cameras came off with the glass. Is there a way to replace or fix this!? I am new to repairing and I’m freaking out. Please help.
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Okay, after some digging I found the part you're talking about. If you take a look at the iPhone 13 Pro teardown Step 9 shows that part being removed.
Imagem
I realize this is for a 13 Pro rather than the Pro Max, but a quick check shows a virtually identical part mistakenly being called the GPS Antenna being sold online. Here's one example of a vendor selling that part.
iPhone 13 Pro Max GPS Antenna Flex Cable Replacement – Repairs Universe
Technically it's the Ultra Wideband antenna, but if you want to search for it online you'll need to search for GPS antenna instead, as that's what everyone is calling it.
Sorry to say there isn't much in the way of guides to help you out with replacing that part, but I'm pretty sure at a minimum you'll need to remove the front camera assembly and the earpiece speaker.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Hello Jerry thank you so much for this information and for getting back to me so fast. I will look into this part. I really appreciate it!
por Compartilhar
Adicionar a sua resposta
Purple Phantom Repairs será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 67
Ao todo: 67
