Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas para o smartphone Android Infinix HOT 30, modelo X6831. Ele possui uma tela de 6,78 polegadas e 90 Hz, processador MediaTek Helio G88, câmera traseira de 50 MP e bateria de 5000 mAh.
The phone Camera problem
My phone camera isn't responding
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@alaminmuhammad you should clarify which camera and when does it not respond. This could be a bad camera module or a software issue. Try to start your phone in safe mode. To get into safe mode turn off your phone, turn it back on, and hold the Volume Down button as soon as the Infinix logo appears. Check your camera in that mode. Since safe mode disables all third-party apps and if you camera works in that, you know that this is an issue with a third part App that maybe blocking access to the camera. You will need to uninstall those Apps until you have access again. If your camera does not work in safe mode either, it is most likely the camera module that has failed.
Since iFixit does not yet have a specific guide for this, use something like this video for that. Start at 6:40 for the disassembly. Of course, skip the parts that do not pertain to the mainboard and the cameras itself. You do not have to completely disassemble your phone for this :-)
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person who has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Alamin Muhammad será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 54
Ao todo: 70
