Where should the flat washer be placed?
where should the flat washer be placed? It fell out before I could see where it was located
Esta é uma boa pergunta?
flat washers normally go on screws. If the screw has a lock washer, they go on after the lock washer.
If it is just a spacer, then you need an exploded view, that you may be able to find on a parts supplier web site.
Esta resposta foi útil?
Looking at the parts diagram there are no washers used.
Did you mean the diffusion plate by any chance?
See the image below for its location
(click on image)
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 16
Ao todo: 16
