Ir para o conteúdo principal
A sétima geração do Ford Fiesta focou mais em um interior refinado e em tecnologia avançada, incluindo uma transição para a eletrificação antes que o modelo fosse finalmente descontinuado. A linha principal de motores consistia no 1.0 EcoBoost turbo de três cilindros, no 1.1 Ti-VCT e no 1.5 TDCi a diesel. Para o modelo ST, focado em desempenho, havia um motor EcoBoost de três cilindros e 1,5 L, entregando 197 cv e desativação de cilindros para maior economia de combustível.
Reverse not functioning after replacing battery
I changed the car battery then the reverse function is not functioning. When drivibg forward there is noticeable not smooth when during shifting
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@zacsevilla it is possible that when you disconnected the battery the Transmission Control Module (TCM) may have lost its Keep Alive Memory (KAM). Erasing that memory means the computer has forgotten the precise bite points of the clutches and the exact positions of the internal shift forks, which frequently results in a locked-out reverse gear and shuddering forward shifts.
Start of by performing a Static Idle Relearn which will force the transmission to find the baseline positions. Start the engine and let it reach normal operating temperature. With your foot firmly pressing the brake pedal, shift from Park down into Reverse, Neutral, Drive, and Low/Sport. Leave the shifter in each position for exactly 5 seconds before moving to the next. Shift back up to Park in the same 5-second intervals. Turn the key off, wait 30 seconds, and restart to see if Reverse engages.
Now, if that did not work you will most likely need to run a TCM Adaptive Relearn via OBDII You will need to connect a diagnostic interface (like an ELM327 adapter) and use software like FORScan to run the "TCM Adaptive Learning" service procedure. That maybe one of those tasks where a professional shop will come in handy. The adapter as well as the software may not be that easy to come by and/or use.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Zac Sevilla será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 11
Últimos 30 dias: 34
Ao todo: 88
