Ir para o conteúdo principal
Modelo: Cinema 600 Número do Modelo: 1068777 ASIN: B089B6VS11 UPC: 743878043822 Lançado em 15 de julho de 2020
Subwoofer not powering on
My Klipsch Cinema 600 powers on and works fine, but the subwoofer simply died. No light, nothing. I have verified the cord and outlet, both good. I opened it up looking for a fuse and I didn't find one. Any advice? Other threads are about the main unit power supply.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi @jandsilentbob
If I've found the correct board there is a fuse on it.
It is a T3.15A 250V square plastic fuse.
Below is an image that shows where it is located. The fuse rating is printed on the board.
If it is blown, ensure that you get a T3.15A 250V fuse as a replacement and not a 3.15A 250V fuse. The T rating is important as it denotes that it is a slow blow fuse and not a normal fast acting fuse. A normal fuse having the same rating will blow immediately that the power is connected to the device due to the high inrush currents that flow whereas the slow blow fuse will hold until these currents subside. They last for about 4-8mS (milliseconds)
Imagem
(click on image)
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
jandsilentbob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 24
Últimos 30 dias: 30
Ao todo: 30
