Ir para o conteúdo principal
O Fujitsu Lifebook E753 foi lançado em 2013 como um laptop empresarial de 15,6 polegadas. Ele é equipado com processadores Intel Core de 3ª Geração (Ivy Bridge). Suporta até 16 GB de memória RAM DDR3, possui um teclado de tamanho completo com teclado numérico dedicado e pesa aproximadamente 2,1 kg. Sua bateria padrão de 6 células (disponibilidade de 63 Wh ou 72 Wh) oferece cerca de 12 horas de funcionamento. O E753 possui uma baia modular, que pode aceitar uma bateria secundária de 28 Wh. Quando ambas as baterias são utilizadas, o laptop pode atingir de 18 a 21 horas de autonomia da bateria total.
Laptop not Powering On
After not charging my laptop for a long while due to Power Outage, When the Power supply was restored, I tried charging it and after charging, It did not switch on. I've tried putting it on AC mode - Plugging it without the battery installed - and it still didn't work.
Please what should I do
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@ujuakuokafor first you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Use something like this video to open your laptop up. Post Some good pictures of what your motherboard looks like with your question. That way we can see what you see. Adicionar imagens a uma pergunta já existente
Your computer most likely does have a Fujitsu 621881-X1 motherboard and I have not been able to find the schematics for this. You will need to depend on your own troubleshooting skills if the error is with the motherboard.
Esta resposta foi útil?
Pontuação 0
1 comentário:
Thanks, I'll try opening my Motherboard, snap the picture and send it back
por Compartilhar
Adicionar a sua resposta
Ujuaku Okafor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 45
Ao todo: 104
