It no longer works
It doesn't work, and when you try to turn it on, it stays off and doesn't turn on. It doesn't charge, and its fan doesn't turn on or give any indication that it's charging.
Esta é uma boa pergunta?
I assume you subbed the adapter or check the output voltage.
And tried running it with the adapter plugged in.
If so, there are multiple possibilities and they are all internal.
Maybe the simplist thing might be a bad pwr socket on the computer. That is a plug in replacement
Worst case is a bad MB.
It has a seperate pwr board, which is aslo a plug in replacement.
The biggest problem is figuring out which one it is, or u could just part jockey it - which is what a repair shop would do, but they gave the parts to sub.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 15
Ao todo: 49
Hi @adambouchear
What is the full model number of the laptop as shown on the product information label on the bottom of the laptop?
por jayeff
