Um celular intermediário da Realme, lançado em 14 de setembro de 2020. Equipado com Snapdragon 720G e até 8 GB de RAM com 128 GB de armazenamento interno, também possui uma tela Super AMOLED de 6,4".
If the phone is not charging, have you tried using a different, known working, compatible charger or charger cable and checked if it started to charge?
Hi @ashishmukhi
Has the phone been dropped or gotten wet at all?
What have you tried?
por jayeff
Try using a different charging cable and plug.
Ensure the port on the phone is clear of all and any debris to the charing cable can insert properly.
Also try using a different plug on the wall to charge.
If none of these work, it would be a problem with the phone itself and then require going to a shop to be fixed.
por Charlie Vanstone
