Flashing Green Light Despite Not Charging.
My Galaxy Buds 2 Pro case can't stop Flashing Light despite not charging. Any way to fix this? Battery is burning out 3x faster because it can't turn off.
Esta é uma boa pergunta?
@michaelcao45144, first thing you want to do is remember that repair shops just want your hard-earned money. iFixit tries to empower you to fix your own devices to save your money and to keep these electronics out of the mountains of e-waste that we create every single day.
At this point, I would strongly suggest you give it a try and fix this yourself. Yes, those earbuds are an absolute bear to open, but it's not impossible if you take your time.
Since iFixit does not yet have a specific guide for this, use something like this video to get inside the buds and replace the batteries. RE-evaluate your earbuds once you have new batteries installed.
While you work on your earbuds, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same issues with their device. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Hello,
Your most likely cause to the problem is that the batteries for the earbuds and the case are reaching the end of service. You should send this to a certified repair shop to replace the dead batteries.
Good luck,
T
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Ao todo: 43
