How fast I am going
The speed gauge is not correct. How do I fix this
Esta é uma boa pergunta?
Could be a VSS (vehicle speed sensor) wiring problem (loose connection) or a faulty VSS connected to the transmission in the vehicle.
Here's an image showing where it is located so that you can check if it is connected OK or if you need to replace it.
(click on image)
Here's a video that may also help.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 68
