Ir para o conteúdo principal
A terceira revisão do clássico Controle Sem Fio Xbox foi lançada em novembro de 2020, acompanhando o Xbox Series X e Series S. Este controle é compatível com versões anteriores dos consoles Xbox One e PCs.
Potentiometer of joystick replacement problem
Hello,
I replaced the one potentiometer of joystick from a Xbox Series X controller but when trying it I was not able to calibrate it. Changed again and same thing. Does the potentiometer has to have an initial resistance value so I am able to calibrated? Maybe the resistance is very high/low to be able to
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Did you just change the potentiometer only or the whole joystick assembly? Did you try to cslibrate on a PC or an Xbox?
por
I changed only the potentiometer 2 times with no success. The the whole joystick worked. I calibrated it on a emulator in PC because I don't have an actual working Xbox Series X
por
Okay, glad that replacing the joystick worked. Should be OK now! Calibrating on the PC should do it! Have a nice day :)!
por
Adicionar um comentário
1 resposta
Solução escolhida
Hi!
Whenever the potentiometer won't fix it, it's advised to replace the joystick assembly completely.
You can follow this guide for that: Substituição do joystick do controle sem fio do Xbox Series X/S
After this is done, you can try to calibrate them again.
Please let us know how it goes!
Esta resposta foi útil?
Pontuação 2
4 comentários:
Hi,
Thank you very much. I discovered that I was using the same potentiometers I use for PS5 controller and the resistance value is different (PS5 2k3 ohm and Xbox 10k ohm) so that was the issue why I could not calibrate it
por
Ah that explains it!! It’s correct that they are different. Glad that you found out :)! Have a great day!
por
I replaced all my ps4 controller sticks with hall sensor ones. Never had a problem since.
por
Yes that works :)! But this is regarding a Xbox controller. I heard that sometimes it can interfere here with the magnets.
por
Adicionar a sua resposta
sascha bauló martínez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 39
Ao todo: 160
