Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Samsung Galaxy A31. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Samsung Galaxy A31.
Not switching my phone
When iam doing charging it just vibrate it will not will not on the phone and I remove from charging and try to switch on it will just vibrate and not showing anything
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@saimashaikh "it just vibrate it will not will not on" what you are describing are the symptoms of a failed screen. Replace the display and re-evaluate.
Use something like this video as your guide. Of course you can also use the guide from here. It is written in French. Use a browser that does the translation for you, if needed. Replacement displays are readily available. Just do an online search and select a vendor that appeals to you.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem with their device as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Saima Shaikh será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 42
