Ir para o conteúdo principal
Um conjunto abrangente de informações de reparo para dispositivos domésticos funcionais.
How to repair electrical socket plugs
How do I repair plugs when I insert an extension lead it doesn’t work
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Different countries have different wiring standards and how power is fused. So I can't tell you where to look as there are quite a few possibilities. You may want to get a local electrician in as he is equipped to deal with most of the possibilities.
Keep in mind you can get hurt if you make a mistake!
I would look for the breaker/fuse panel and locate the breaker/fuse for the outlet to see if it's still good. If not you may have a short in the line.
Esta resposta foi útil?
Pontuação 0
@humphreygxowa what country do you live in? Let's see what the wiring standards are wherever you live. What have you already checked and what have you already tried?
Pontuação 0
1 comentário:
South Africa
por
Adicionar a sua resposta
Humphrey Gxowa será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Ao todo: 80
