Ir para o conteúdo principal
Cassette player not playing
I have a Sony cassette player that can run rewind and fast forward without issue, but when I hit play, it will not play. The spindles did not move. What are some troubleshooting steps I can do to identify the issue?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@seanbarry most Sony cassette players fast forward and rewind run directly off a gear train. The Play function depends on a rubber belt to spin the heavy metal capstan (the metal pin that pulls the tape across the play head). If that main belt has stretched out, snapped, the play mechanism will not engage.
This is a general answer to a general question. We will need to know your cassette players exact model number to try and help you in more detail.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
sean barry será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 54
