Ir para o conteúdo principal
Informações de reparo para lava-louças Samsung.
Samsung dishwasher auto light blinking
Hey guys, my Samsung dishwasher auto light blinks after the wash cycle when reaching the rinse cycle. Each time, I can simply switch it off and switch it on then start a new full cycle without issue.
I've read that it's an issue with the water supply, but I don't understand how it wouldn't fail on the initial wash cycle, or why it doesn't fail at all on the subsequent run.
I tried priming the hot water beforehand and during the cycle to make sure hot water is always available, but it didn't work.
What should I do?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi @charlesmat24088
What is the model number of the dishwasher?
por
Hey @jayeff model is DW80J3020US
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @charlesmat24088
See p.59 (61 of 89 pdf) in the service manual for how to enter the Service Inspection mode and perform mode 1 checks.
On p.61 (63 of 89 pdf) it details how to check the if the water inlet system is OK.
There's a mention of a flowmeter which measures the amount of water entering but I can't find it in the manual except that it connects to the control board on the control board connector CN301 pin 5 - see p.81 (83 of 89 pdf). Usually flowmeters are a reed switch which is magnetically operated by a turbine wheel with a magnet attached which is in the flow path. As the wheel turns it causes the reed switch to send pulses to the control board which counts them to know how much water has entered the machine.
Have read that it is located near the water inlet valve. Just mentioning this if all the other tests prove OK.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thanks @jayeff, I will start troubleshooting!
por
Adicionar a sua resposta
Charles Mathieu será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 92
