Ir para o conteúdo principal
Informações de reparo, desmontagem e resolução de problemas para o smartphone Android TECNO Spark 20, identificado pelo modelo TECNO KJ5.
How can I fix the battery
N
Esta é uma boa pergunta?
Pontuação 2
5 comentários
I want to replace the battery
por
@shreevishnumk replace the battery as suggested in the answer.
por
My phone goes off every time i unplug the charger
por
Je une problème de batterie
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@higenyipeter you can replace a battery but not fix a battery. Since iFixit does not yet have a specific guide for that, use something like this video Slow it down and the music is bit to much a well :-) Start at 5:02 min right up to 7:28 min to see how to remove the battery. Replacement batteries are readily available at many online places.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Higenyi Peter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 64
Ao todo: 228
